beans Occasional Visitor
Posted: Tue Jun 26, 2007 9:29 am Post subject: clock on tom tom one |
I have a tomtom one original and notice recently when turning on that the clock is often showing the wrong time
does anyone know why.
Regards, Beans |
Oldboy Pocket GPS Moderator
Posted: Tue Jun 26, 2007 10:24 am Post subject: |
Which version software are you using?
This used to be a problem on all the devices using early software versions. _________________ Richard
TT Via 135 App 12.075: Europe Map v1140 |
voice_of_reason Regular Visitor
Posted: Tue Jun 26, 2007 12:34 pm Post subject: |
Continuing the theme....
Does the TomTom ONE ever sync its clock automatically from the satellites? I noticed there's an option in the menus to do this, and it seems to work, but I'd have thought it would make more sense to autmatically sync the clock every time it gets a satellite fix - but I'm not sure that it does this. |
Andy_P Pocket GPS Moderator
Posted: Tue Jun 26, 2007 1:24 pm Post subject: |
Nope. AFAIK it only syncs when you tap the button. It also only syncs the minutes or seconds, as there is no other allowance for different time zones. |
Posted: Tue Jun 26, 2007 8:57 pm Post subject: |
Hi Richard,its running version 6.150 |
Posted: Tue Jun 26, 2007 9:33 pm Post subject: |
I can't remember if I had a problem with that version or not.
I know I don't now. _________________ Richard
Gmonkey Frequent Visitor
Joined: Oct 17, 2005 Posts: 390 Location: Washington DC
Posted: Wed Jun 27, 2007 10:15 pm Post subject: |
From what I've read, the device prompts you to enter a time manually. However, you CAN sync it with the satellite - however, the time zone will be set to GMT. You must change the time zone manually.
Hope this helps! |
trevor.dowle Lifetime Member
Posted: Sat Jun 30, 2007 1:23 pm Post subject: |
Gmonkey wrote: | From what I've read, the device prompts you to enter a time manually. However, you CAN sync it with the satellite - however, the time zone will be set to GMT. You must change the time zone manually.
Hope this helps! |
I asked a similar question several months ago, when I had problems when I synched, and TomTom continuously set itself to UTC.
The solution is to synch the time, which will display in UTC, then alter the hours to BST and synch again. This sets the memory to BST. _________________ Regards
Trev Dowle
TomTom 730 T |
Posted: Sat Jun 30, 2007 2:32 pm Post subject: |
Thanks everyone,
Beans |
