Pocket GPS World :: View topic - TomTom910 transfering poi to a new map
phoenix
PostPosted: Mon Jun 25, 2007 11:09 pm    Post subject: TomTom910 transfering poi to a new map Reply with quote
I have just loaded a new updated map of western europe on my 910, but i can't see any way of enabling the poi that are on the old western and central europe map .Is there a way of transfering them, as they appear on the 910 in tom tom home.Also is there away of transfering your favorite places from the old map to the new? Any help is much appreciated.
tanda
PostPosted: Mon Jun 25, 2007 11:16 pm    Post subject: Reply with quote
Yes, "MapSettings.cfg", in the map folder. Just copy it across
from your old map folder, into the new map folder, and the POI.DAT file.
Audi A3 Sline sat nav
PostPosted: Mon Jun 25, 2007 11:36 pm    Post subject: Reply with quote
Tanda's advice will only copy your favourites to the new map.
To copy your user-loaded POIs, you need to copy all the ".ov2" files and the same-named ".bmp"s from the old map folder to the new map folder as well.
You can do this using Windows Explorer and normal computer copy-and-paste methods. Home is not needed.
If you wanted to replace the built-in POIs with those from the old map you would need to replace the "poi.dat" file with the one from the old map, but that seems pointless as you cannot merge the old and new together.
Copying the favourites is explained more fully in the TomTom FAQs at the top of this forum section (#12 HERE), or I wrote a guide to doing both favourites and POIs HERE
phoenix
PostPosted: Tue Jun 26, 2007 6:43 pm    Post subject: Reply with quote
thanks for the help, peter
NickC
PostPosted: Fri Jul 06, 2007 8:48 am    Post subject: Reply with quote
Good old search facility. I was just about to ask this question!!!
Smile
NickC
PostPosted: Fri Jul 06, 2007 9:04 am    Post subject: Reply with quote
Ah - think I've done something wrong!!! TomTom won't switch on now!!! I tried resetting and now I get the TomTom screen with two red hands and the drum beat - then it immediately goes blank again.
Stupidly I didn't back up the Mapsettings config file first.
Is it MapSettings.cfg? That's what I had in my old GB map folder - but I don't remember seeing those capitals in the new Western Europe folder.
Can anyone help?
Cheers, Nick
PostPosted: Fri Jul 06, 2007 10:47 am    Post subject: Reply with quote
The MapSetting.cfg File won't cause that to happen. If the Software can't see the correct file on start up it will just create a new one.
Did you Safely Remove Hardware when you disconnected from the PC?
Do you have a Backup? Have you done a 30 secs Reset?
If the Reset or Backup doesn't work, you might have to Reformat the SD Card (I believe you have a ONE) and re-load everything.
NickC
PostPosted: Fri Jul 06, 2007 10:51 am    Post subject: Reply with quote
No - I didn't do a safely remove hardware, and no I didn't do a back up(silly me!!!!)
I didn't do a 30 second reset, just a quick poke, so I'll try those 2 things and see how I get on.
Thanks for your help!!!
NickC
PostPosted: Fri Jul 06, 2007 11:17 am    Post subject: Reply with quote
Panic over!!! I went in the car, plugged it in and it worked ok. It now switches on ok unplugged from the car.
Perhaps the battery wasn't charged enough to do a full boot.
Thanks for your help Oldboy.
thebinman
Banned
PostPosted: Fri Jul 06, 2007 11:41 am    Post subject: Reply with quote
Sounds about right Wink
PostPosted: Fri Jul 06, 2007 1:30 pm    Post subject: Reply with quote
Well done for using "search". We love you for that!! Laughing
But go to the back of the class for not doing a backup first! Evil or Very Mad
DO IT NOW!!! (instructions for doing a "proper" backup (i.e. not using TT's Home utility) are #1 in the FAQs Click Here
NickC
PostPosted: Fri Jul 06, 2007 1:39 pm    Post subject: Reply with quote
I consider myself severely rebuked and will do a back up NOW!!!
Embarassed
PostPosted: Fri Jul 06, 2007 1:53 pm    Post subject: Reply with quote
Thumbs Up
(And once you've done it... do another one! You can never have too many backups :D )
NickC
PostPosted: Fri Jul 06, 2007 2:08 pm    Post subject: Reply with quote
OK - Back up done on work PC. Will do one at home tonight!!!
Laughing
RQ
PostPosted: Fri Jul 06, 2007 10:15 pm    Post subject: Reply with quote
I am not sure if you are doing a backup or a copy?
You would be safer to do a copy using Windows Explorer. Make sure that all files are showing - Tools, Folder Options, View and enable show all hidden files and folders
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
22.064 (26 Jun 24)
