Pocket GPS World :: View topic - Help - I Loaded the Euro Data Base and my Garmin Locked Up
Schnitzergs
PostPosted: Mon Jun 25, 2007 3:54 pm    Post subject: Help - I Loaded the Euro Data Base and my Garmin Locked Up Reply with quote
Help - I've just added the Euro camera poi to the UK data base & my Quest 2 locked up and won't clear, even after forced reset inc. removing user data. Also tried tried turn on with both off & find buttons in for reset. Nothing works - it just gets to the welcome screen & won't go any further. Coincidence or something else? No idea, but have spoken to Garmin & they say its a back to them repair - i.e £118! Before I send it does anyone have any suggestions for a fix? Quest has latest operating system & v9 mapping.
PostPosted: Mon Jun 25, 2007 5:14 pm    Post subject: Reply with quote
I don't know much about Garmin, but might THIS THREAD be relevant? It says it's for the Streetpilot i3, but it might be similar.
Schnitzergs
PostPosted: Mon Jun 25, 2007 6:01 pm    Post subject: Reply with quote
Thank you for the tip. It certainly seems to be the same kind of problem- as I was loading extra poi's in at the time it has probably tipped over the edge. I tried the POI loader but it can't make a connection to the Quest and so it won't work. It seems the firmware is corrupted or blocked in some way & I can't get to it to reload it. I have done a full reset so I suspect it has removed the pois but somehow cant replace the operating software. Windows device manager sees the unit & thinks it works OK. I have also now tried opening the unit & disconnecting battery but no change in responses. Still trying to find a solution.
22.094 (25 Sep 24)
