Pocket GPS World :: View topic - GR-230 satellite acquiring times
gps_user
PostPosted: Tue Mar 16, 2004 11:36 pm    Post subject: GR-230 satellite acquiring times Reply with quote
Does it take longer for my unit to acquire satellites if I'm on the move (in the car) or is the GR-230 just slow?
Its weird because I'm sure it used to be faster than this when I first bought it. Question
PostPosted: Tue Mar 16, 2004 11:50 pm    Post subject: Reply with quote
If you commence your drive it will take a lot longer sometimes to acquire satellites. If you sit and time it in car, you should be looking around the 1 min mark, certainly less than 1.5 mins.
gps_user
PostPosted: Tue Mar 16, 2004 11:58 pm    Post subject: Reply with quote
Thanks for this. Yes I'll do some testing.
Skippy
PostPosted: Wed Mar 17, 2004 1:17 am    Post subject: Re: GR-230 satellite acquiring times Reply with quote
Yes.
The receiver needs to have an uninterrupted view of the satellite for long enough to get the clock and ephemeris data in order to "aquire" it. This data stream is sent continuously and repeats every 30 seconds.
If the signal is interrupted (as it often is when you are moving) during the aquisition then it has to wait another 30 seconds until the data it missed is retransmitted.
Once it has the initial lock, it can reaquire the satellite almost instantly.
gps_user
PostPosted: Wed Mar 17, 2004 12:10 pm    Post subject: Reply with quote
Hi Skippy,
Thanks, that make sense because when I start driving it can take anything up to 5mins before I connects.
22.064 (26 Jun 24)
