Dave Frequent Visitor
Posted: Fri Mar 12, 2004 11:16 pm Post subject: POIEdit v3.0 Released |
Dave over at dnote.nl and the author of POIEdit has updated POIEdit to v3.0. The main differences are more on the server side than client side, but it will enable us to categorise POI's easier in the future.
The new version can be downloaded from the dnote.nl website or run an earlier version of POIEdit and let it update to the new version. |
Rogerfrit Regular Visitor
Joined: Dec 17, 2003 Posts: 141 Location: North Devon - England
Posted: Fri Mar 12, 2004 11:51 pm Post subject: |
It also works with ActiveSync 3.7 - saving a lot of hassle.
Roger harding |
CS Lifetime Member
Posted: Sat Mar 13, 2004 12:14 am Post subject: POI Edit V 3.0 |
Ironically the "AutoUpdate Now" stopped working on my Compaq iPaq 3800 tonight. It had been working perfectly OK using POI Edit V2.6.0 Build 47 but now I'm getting "Cannot retrieve proxy settings. Probably these are set to Auto Detect or Auto Confirguration. You can set proxy settings manually from the Online|Proxy Settings menu" But I haven't knowlingly changed anything since the last AutoUpdate download.
Has the latest release anything to do with my problem?
And do I need to remove the earlier version from my iPaq before I transfer V3 across or would this mean losing any previously stored or created POIs? |
Posted: Sat Mar 13, 2004 9:46 pm Post subject: |
It's possible these are defaulting to ON and these should be turned off. If you turn off these settings you should be okay.
The great thing about POIEdit is it's a PC program, there's nothing to remove from the iPAQ as it doesn't install anything, it only copies OV2 files and BMP files to your Pocket PC. |
Cessquill Regular Visitor
Joined: 19/11/2002 21:48:47 Posts: 160 Location: United Kingdom
Posted: Mon Mar 15, 2004 10:42 am Post subject: |
Cool, will be downloading that later. Does it still alert you when it's finished syncing, meaning that it's not really practical to automatically leave working all the time? _________________ What's going on? Where am I? |
Posted: Mon Mar 15, 2004 6:34 pm Post subject: |
All that is needed now is a decent bmp. of the British Isles. I have downloaded one, but once calibrated is out in some places by about 50 miles - not very good.
Any suggestions?
Roger Harding |
Posted: Tue Mar 16, 2004 9:54 am Post subject: |
CS - I have the same problem as you at this end. Did you resolve the issue? All I've found is an automatic/manual toggle for the proxy settings (that's not where the error message said it would be) and both produce the same error message.
BAH! _________________ What's going on? Where am I? |
Posted: Tue Mar 16, 2004 1:33 pm Post subject: |
Check the FAQ out to resolve proxy message issues. |
Posted: Tue Mar 16, 2004 7:56 pm Post subject: |
Something completely different. It was Windows XP's built in Firewall. Turns out it had suddenly started blocking POI Edit and my WinMX account. Stupid thing. I've got ZoneAlarm running, so I've just turned the firewall off.
Cheers anyway. _________________ What's going on? Where am I? |
