999tommo Frequent Visitor
Posted: Fri Jun 08, 2007 11:06 pm Post subject: Speed Camera Warnings |
Sorry folks.. The other day, I was browsing through threads and found that someone had created a chart giving approximate distances to set up for camera warnings, based on different speed limits.
I have searched for ages and cannot find where I saw this chart.
Can the author of it, or anyone else with knowledge please point me in the right direction. It was only in the last few days.
Thanks,
Tommo _________________ Tommo...
Regularly absent, but still here in spirit ! |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Jun 08, 2007 11:17 pm Post subject: |
Actual Times/Distances
Mph - 30s - 20s - 15s - 10secs warning.
80 - 1173- 782 - 587 - 391 yards
70 - 1026- 684 - 513 - 342
60 - 879 - 586 - 440 - 293
50 - 732 - 488 - 366 - 244
40 - 588 - 392 - 294 - 196
30 - 441 - 294 - 221 - 147
20 - 294 - 196 - 147 - 98
These are the figures I recommend using... as it has a built in 10mph buffer zone should anyome stray a little over the limit.
Mph - 30s - 20s - 15s – 10 secs warning.
70 - 1173- 782 - 587 - 391 yards
60 - 1026- 684 - 513 - 342
50 - 879 - 586 - 440 - 293
40 - 732 - 488 - 366 - 244
30 - 588 - 392 - 294 - 196
20 - 441 - 294 - 221 - 147 _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Fri Jun 08, 2007 11:25 pm Post subject: |
Cheers L.P.
You are a star. _________________ Tommo...
DennisN Tired Old Man
Posted: Fri Jun 08, 2007 11:30 pm Post subject: |
Here y'go (it's quite a scroll down to the chart).
http://www.pocketgpsworld.com/uksafetycameras-tomtom-go-910.php
Most people recommend rounding them off (e.g. for a 20 second warning in 20mph zone, 200 yards)
There's even a simple theory to get a 20 second warning - just add a zero to the speed, so 20mph = 200 yds, 30mph = 300 yds, 40/400, 50/500, 60/600, 70/700. Remember to worry and make it more complicated by factoring in rear facing, forward facing and long distance forward viewing mobile cameras!
. Lost Property has beaten me again! _________________ Dennis
Two of them are obesiting!! |
Posted: Fri Jun 08, 2007 11:55 pm Post subject: |
Quote: | . Lost Property has beaten me again! |
That makes twice then? :P _________________ Formerly known as Lost_Property
TomDavison Lifetime Member
Joined: Mar 02, 2006 Posts: 384 Location: Bedford, England
Posted: Sat Jun 09, 2007 9:32 am Post subject: |
I'd go along with the 20 second warning, regardless of speed, and also use the simple add a zero that Dennis suggests. However, for mobile sites, regardless of your speed, I use 1000 yards. There is little point in a 30 mph zone, of getting the mobile warning 300 yards from the mobile. He'd have taken a reading well before then.
Similarly, for the average speed areas, I set for a 300 yard warning. They don't start to time you until you have passed the first camera, and you have plenty of time to get your average speed down by the next one, even if you're still "Just" over the limit as you enter the zone. |
Posted: Sun Jun 10, 2007 11:20 am Post subject: |
Thanks everyone.
I just put another new post on. I wondered who would be first to answer, Lost Property or DennisN.
Neither.....super quick Mike Alder was the star..... _________________ Tommo...
sgould Frequent Visitor
Posted: Sun Jun 10, 2007 12:29 pm Post subject: |
Using those distances is fine if you drive at around the speed limit and just need a reminder.
If you drive at 90 mph everywhere, you will need more time/longer distance to slow to the lower speed limits. In that case you may want to increase the time distance as the limit decreases! ;) _________________ TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Kenwood DNX-4210DAB with Garmin maps |
Posted: Sun Jun 10, 2007 12:51 pm Post subject: |
999tommo wrote: | I just put another new post on. I wondered who would be first to answer, Lost Property or DennisN.
Neither.....super quick Mike Alder was the star..... |
I think I should point out that Lost Property and I are in a contest with only two participants - we are not allowed out with the big boys like Mike Alder. Just for the record, Lost property's winning (by quite a long way too). I have several handicaps which he doesn't - I don't know much and can hardly type, to name but two. Maybe I'm just in a contest of one. sgould wrote: | Using those distances is fine if you drive at around the speed limit and just need a reminder.
If you drive at 90 mph everywhere, you will need more time/longer distance to slow to the lower speed limits. In that case you may want to increase the time distance as the limit decreases! | My daughter would probably suggest I only need about 3 seconds warning! _________________ Dennis
Posted: Sun Jun 10, 2007 2:03 pm Post subject: |
If you drive around at 90 in a 60 limit, you still get around 13 seconds to drop your speed to 60. Shouldn't be a problem.
Mind you if its a 30 limit, the 6.8 seconds warning (300yards) could be quite exciting. |
Posted: Sun Jun 10, 2007 2:42 pm Post subject: |
Quote: | Using those distances is fine if you drive at around the speed limit and just need a reminder. |
Staying at or below the limit makes the actual figures pointless, that's why I upped them all by 10mph incase people drift over the limit, e.g. quite eay downhill.
Quote: | If you drive at 90 mph everywhere, you will need more time/longer distance to slow to the lower speed limits. In that case you may want to increase the time distance as the limit decreases! |
Shouldn't be a problem as most speedo's are up to 10% out so 90 on the clock could be actual 81.
Personally I've gone for the 20 second warning, as has been said 'Easier to set up', for all fixed cameras and a minimum 440 yards for mobiles upping to 500 yards at 50, 600 at 60 and 700 at 70. I don't bother setting red light cameras as the traffic lights themselves are a bit of a givaway anyway.
Quote: | My daughter would probably suggest I only need about 3 seconds warning! | THAT LONG! Tut, tut. _________________ Formerly known as Lost_Property
Posted: Sun Jun 10, 2007 3:10 pm Post subject: |
[quote="Lost_Property"] Quote: | 440 yards for mobiles upping to 500 yards at 50, 600 at 60 and 700 at 70. |
Not a wise move in my opinion. The mobiles can take a reading up to a kilometer away, regardless of speed limit. There is little point in giving yourself 440 yards warning of the camera location, when they'll have read your speed well before the warning occurs.
If we wanted to be pedantic, surely we should be going for 1300 yard in a 30 limit, upping to 1400, 1500, 1600 etc, so that we had appropriate advance warning of the point when we enter the 1000 metre "risk" zone. |
Posted: Sun Jun 10, 2007 4:37 pm Post subject: |
Quote: | There is little point in giving yourself 440 yards warning of the camera location, when they'll have read your speed well before the warning occurs. | Like DennisN, I usually stick within the speed limits. I can of course, like most people, stray a little over but having had only two speed tickets, one in 1959 (motorbike) and the other in 1971 (car), I feel fairly confident I won't be receiving any surprises.
Why do I have the database? For when I am in unfamiliar territory and it's a reminder the area is probably one which has had several accidents. I don't use my Sat Nav/camera database for routes/areas I know.
It may feel to those that speed everywhere that they are getting there much quicker than those they pass but take for example the M25, which is about 126 miles around. Person a travels all the way round at 70 and person b at 80. Person a takes 1h 48m and person b 1h 36m, just 12 minutes difference, and that's with NO other traffic and at a constant speed.
Double that distance is like travelling from London to Cornwall, so the difference would be 24 minutes but most of the time you would be travelling at a slower speed e.g single carriageways/towns, slow moving traffic. Nah, it just don't pay to speed, what's the point of getting all up tight? Make the journey as pleasant and relaxing as possible, get there safe and without a ticket. :D _________________ Formerly known as Lost_Property
Posted: Sun Jun 10, 2007 5:54 pm Post subject: |
DennisN wrote: | 999tommo wrote: | I just put another new post on. I wondered who would be first to answer, Lost Property or DennisN.
I think I should point out that Lost Property and I are in a contest with only two participants - we are not allowed out with the big boys like Mike Alder. | I forgot to add that Mike Alder and all the others who hurry to answer you are doing it out of self interest. They hope to be able in court to use the mitigation that "Well, yes yer onner, I was going a bit quick, but it was only because I was rushing home to answer a post from 999tommo, so it doesn't count and you can let me off". _________________ Dennis
Posted: Sun Jun 10, 2007 8:20 pm Post subject: |
Quote: | "Well, yes yer onner, I was going a bit quick, but it was only because I was rushing home to answer a post from 999tommo, so it doesn't count and you can let me off". |
We'd get off because you'd say
'Lost_Property and 'I were rushing home to answer a question by p999tommo and we can't remember who was driving the slowest on the day'. :P _________________ Formerly known as Lost_Property
