Pocket GPS World :: View topic - Tomtom one Origional new Harddrive!!!
azzurrafm
PostPosted: Mon Jun 04, 2007 7:32 pm    Post subject: Tomtom one Origional new Harddrive!!! Reply with quote
I recently had my tomtom one origional repaired and a new battery, GPS module and its hard drive were replaced. I have since been able to get the actual Great Britain map working but the speed cameras from tomtomOV2 (pocketgps) won't work it says no GPS device. What am i doing wrong????
Please help.
PostPosted: Mon Jun 04, 2007 7:44 pm    Post subject: Reply with quote
I am somewhat confused by your post, the TomTom One does not have a Hard Drive, it uses an SD memory card?
Have you re-installed the speed camera database since getting the device back from repair? - if not you will need to re-install the database to the map folder on the memory card AND configure the Warn When Near POI option for each POI category installed (Change Preferences/ Manage POI/ Warn When Near POI) - Mike
azzurrafm
PostPosted: Mon Jun 04, 2007 7:54 pm    Post subject: tomtom one Origional new Harddrive!!! Reply with quote
I got it back and basically everything was replaced (sorry i didn't mean hard drive i meant like its mother board). I downloaded the up to date file and saved them to my Great Britain folder then when i switched my tomtom on it said no GPS device. When i delete the camera files it works fine?????????
PostPosted: Mon Jun 04, 2007 7:56 pm    Post subject: Reply with quote
Did you unzip the download before placing the files into the map folder? - you need to do this, then take the device outside to get a GPS position fix, the POI camera files will not affect the GPS reception of the device - Mike
azzurrafm
PostPosted: Mon Jun 04, 2007 8:25 pm    Post subject: Reply with quote
Thanks for all your help i think its workin now will test it tomorrow on the way to work. Thanks again
PostPosted: Mon Jun 04, 2007 8:39 pm    Post subject: Reply with quote
Why not test it now to be on the safe side, this method doesn't waste fuel so its green :
Switch on the TomTom device, or start the application as applicable.
Go to Advanced Planning (AtoB)
Set a departure point using Address/ Postcode FY43NN House number 95.
Set a destination point using Address/ Postcode PR41AX House number 33.
Now go to Show Route/ Route Demo, set the replay speed to around 100% and sit back watch/ listen, you should receive a Gatso 30 warning within about 45 seconds followed very closely by a Mobile 30 warning.
- Mike
azzurrafm
PostPosted: Mon Jun 04, 2007 9:35 pm    Post subject: tomtom one Origional new Harddrive!!! Reply with quote
May have to take it back to repair as it keeps freezing and switching itself off and won't let me view the demo.
Eldar
PostPosted: Tue Jun 05, 2007 6:29 am    Post subject: Re: tomtom one Origional new Harddrive!!! Reply with quote
Who repaired it if you don't mind me asking?
azzurrafm
PostPosted: Tue Jun 05, 2007 6:55 am    Post subject: Reply with quote
It was Tomtom, as i bought it from comet i purchased the warranty for 3 years and they sent it to tomtom for me. I don't think they are very good.
thebinman
Banned
PostPosted: Tue Jun 05, 2007 11:12 am    Post subject: Re: tomtom one Origional new Harddrive!!! Reply with quote
Ensure it's fully charged, the SD card is not too full and/or try the 30 second reset trick.
azzurrafm
PostPosted: Tue Jun 05, 2007 8:04 pm    Post subject: Reply with quote
Hi, I've tried everything you've said but every time i choose a destination it either freezes and switches it self off or restarts itself (it does this alot). I've had this for about a year and before they repaired it this never happened.
Should i just send it back and request a new one. I rely on my tomtom all the time and having this problem is a real pain!
thebinman
Banned
PostPosted: Tue Jun 05, 2007 8:08 pm    Post subject: Reply with quote
If it IS fully charged & still doing it, send it back again. It should not behave like this!
PostPosted: Wed Jun 06, 2007 6:51 am    Post subject: Reply with quote
azzurrafm wrote:
... but every time i choose a destination it either freezes and switches it self off or restarts itself (it does this alot).
It's a classic symptom of not having enough Free Memory on the SD Card.
Usually a minimum of 2MB is recommended.
thebinman
Banned
PostPosted: Wed Jun 06, 2007 9:12 am    Post subject: Reply with quote
That's what I thought but he says he tried all the suggestions to no avail.
PostPosted: Wed Jun 06, 2007 11:08 am    Post subject: Reply with quote
As he didn't post as to how much Free Memory he had, I thought it better to quantify it. Smile
22.064 (26 Jun 24)
