Pocket GPS World :: View topic - Do I need to reload map?
A5tra_G
PostPosted: Sat Jun 02, 2007 1:44 pm    Post subject: Do I need to reload map? Reply with quote
On my Garmin C310 I currently only have UK & Ireland loaded, I'm going to load the rest of Europe as I'm lending it to a mate, can I just add these maps or will I need to reload the uk as well?
Thanks.
Anita
PostPosted: Sat Jun 02, 2007 2:21 pm    Post subject: Reply with quote
When you load maps it overwrites those already on the unit, so if you want to keep the currently installed maps you will have to include them when you load new ones.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
swing
PostPosted: Sat Jun 02, 2007 2:26 pm    Post subject: Reply with quote
The additional maps will load into a separate file, so won't touch, modify, or affect your built in mapping, and you will not need to copy it again.
However, depending on how much of Europe you try to add, you may run out of space, unless you are loading these additional maps onto a large SD card.
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
Anita
PostPosted: Sat Jun 02, 2007 5:31 pm    Post subject: Reply with quote
I'm sorry if the information I gave was wrong. Sad
I was just repeating the instruction I had from Garmin for installing mapping:
"Please note: Each time you send new mapping onto the unit it will overwrite anything that was there before. For example if you had France on the SD-Card and then sent Germany, the German mapping will overwrite the French mapping. If you wanted both countries on the unit,
then you will need to reselect all the mapping and send it across together.)"
Anita
UK map 1130.12368
Samsung Galaxy S21
swing
PostPosted: Sun Jun 03, 2007 7:55 am    Post subject: Reply with quote
You are correct in that if you send France to the SD card, and then send Belgium as a separate transfer, it will overwrite France, but neither of these transfers will overwrite the UK & Ireland already stored on the device.
Anita
PostPosted: Sun Jun 03, 2007 9:22 am    Post subject: Reply with quote
OK, swing. I'm sorry, I thought it would. Garmin's "Each time you send new mapping onto the unit it will overwrite anything that was there before" is rather ambiguous then. Confused
Anita
UK map 1130.12368
Samsung Galaxy S21
A5tra_G
PostPosted: Sun Jun 03, 2007 10:57 pm    Post subject: Reply with quote
But all my mapping including uk and ireland is stored on the card on my streetpilot c310, so this makes Anita right does it not?
Cheers.
swing
PostPosted: Mon Jun 04, 2007 10:54 am    Post subject: Reply with quote
Ah, but no...
The built in mapping will be stored in a file called gmapprom.img, whereas these additional maps are all stored in a file called gmapsupp.img - this is the file that gets overwritten with whatever is transferred, hence why you lose whatever has already been transferred.
As long as you have a gmapprom.img file (probably around 180Mb for UK & Ireland, depending on the exact version of the map) then you will keep this, irrespective of what you do with MapSource.
Of course, as with any other major "change" to the unit, I would recommend a full backup beforehand to allow you to recover from any mistakes (by you, or by the software).
Anita
PostPosted: Mon Jun 04, 2007 11:32 am    Post subject: Reply with quote
Ahhh, the i3 is obviously different from the rest of the Streetpilot series, as it only has the gmapsupp.img file.
As the v9 DVD and instructions are the same I assumed the maps were handled in the same way.
Sorry for confusing the issue. Stop it!
Anita
UK map 1130.12368
Samsung Galaxy S21
swing
PostPosted: Mon Jun 04, 2007 11:40 am    Post subject: Reply with quote
Ah, well now you've got my wondering too..
I thought the Streetpilot range worked the same as the Nuvi range for maps - but I could be wrong, and Anita might have been right all along!
Definitely a need to take backups first!
Anita
PostPosted: Mon Jun 04, 2007 4:15 pm    Post subject: Reply with quote
At least we both agree on that! :D Thumbs Up
Anita
UK map 1130.12368
Samsung Galaxy S21
22.064 (26 Jun 24)
