Pocket GPS World :: View topic - CoPilot o XDA Orbit Mobile Phone
Sport350
PostPosted: Thu May 31, 2007 10:37 pm    Post subject: CoPilot o XDA Orbit Mobile Phone Reply with quote
I have just got this phone and I am totally new to this type of hardware. I have CoPilot set up as the software, but my biggest problem is I don't seem to be able to get a GPS signal. The XDA has a built in GPS but I can't locate any satellites. Does anyone one on here know about the workings of the XDA ? Do I need to set anything else up to get a signal ? To be honest the manuals that came with the phone are not much use in solving problems.
I'd be grateful for any help.
alix776
PostPosted: Fri Jun 01, 2007 10:48 am    Post subject: Reply with quote
I have 2 t-mobile units one which I set up last week copilot should just pick up the orbits gps receiver automaticlly. have you updated the quickgps application knowing o2*s data tarrifs I'd do it over activesync while connected to your computer.
are you trying to get a gps signal indoor by any chance ?????
device Lumia 950 xl
Sport350
PostPosted: Fri Jun 01, 2007 12:02 pm    Post subject: Reply with quote
Yes, I updated the GPS over the internet, with Activsync. The phone is unlocked and I am using my Vodafone SIM card on it. Which works without any problems. Just looking at what you were saying about data. I don't think my SIM card is set up for data. Does it need data setting up in order for the GPS system to work ? As I say, I am new to this sort of hardware and I am finding my way with it. Thanks for the reply tho'
alix776
PostPosted: Fri Jun 01, 2007 12:58 pm    Post subject: Reply with quote
start copilot and tap the menu on the screen.
from the menu select options
from the next menu select GPS
tap the button that says setup GPS
select other then next
make sure the circle next to manual has a black dot in it
just below there is a box that says com port and below that baud rate
com port should say COM4
and baud rate should say 9600
if not select the above settings from the drop down menus
tap next
you should now get a message saying that the
GPS connection configured successfully. select Finish button to contunie using co pilot select finish thins may say next but select the button in the bottom right hand corner of the screen
now now select gps status and you should see displaying information such as lat/long
device Lumia 950 xl
Sport350
PostPosted: Fri Jun 01, 2007 6:24 pm    Post subject: This did the trick Reply with quote
That latest info did the trick. I followed the instructions and 'Hey Presto' Job complete. Result !! Thanks for the help and information.
Regards
22.064 (26 Jun 24)
