djben9 Occasional Visitor
Posted: Mon May 14, 2007 10:14 pm Post subject: |
i had that problem a while back, i had to find some old image files and it seemed to work. I downloaded the database via the site and not using the manager, it worked on the next update. May be a better answer though from someone else??
I cant seem to get the 1.5.0.0 to work tonight, doesnt want to update  |
marksnsparks Occasional Visitor
Posted: Tue May 15, 2007 8:33 pm Post subject: |
Thanks for the advice, tried it, but still have the gray dots. I've also tried deleting the poi file before using poi loader to reload the files. Also tried using different options in camera manager and the previous version of camera manager. Still get the gray dots.  _________________ _________________
Garmin Nuvi 310 - Version 4.70 Firmware.
V9 Maps
Audio version 2.30
GTM12 - Version 4.80 Firmware
GPS v3.00
bluetooth software version 3.10 |
Ash10 Pocket GPS Verifier
Posted: Wed May 16, 2007 9:02 am Post subject: |
marksnsparks wrote: | Thanks for the advice, tried it, but still have the gray dots. I've also tried deleting the poi file before using poi loader to reload the files. Also tried using different options in camera manager and the previous version of camera manager. Still get the gray dots.  |
The grey blob is displayed by your Garmin when there's no bitmap/icon associated with that type of POI. A bit strange this one, especially as the bitmap files appear present-and-correct in your POI directory.
Once the relevant POI/bitmap files are in your POI directory, it's all down to POI Loader to actually get them into your Garmin - what version are you using? Have you changed this recently, or have you tried a different version?
How many other POI categories do you have? Have you tried just the speed cameras by themselves? |
Posted: Wed May 16, 2007 9:41 pm Post subject: |
Hi Ash, thanks for all your help. I've deleted all the pois and reloaded from the camera database page using camera manager. That's solved the problem. The POI loader version is 2.3.2.0
I have to admit I had inadvertently loaded far too many poi categories. There must be a limit where this problem starts. Wonder if the answer is 257? _________________ _________________
V9 Maps
Audio version 2.30
GPS v3.00
philpugh Lifetime Member
Posted: Thu May 17, 2007 10:59 am Post subject: |
Just to add my thanks to Ash10 for his wonderful s/w.
The V2 beta does everything that I would like - nice clean speed icons and adding voices also. It's much easier than using the 2.4.0.0 beta POI Loader and WAV files. Produces much smaller .GPI file also.
Now all I have to do is convert my modified Liz Whittaker voices into MP3 - a job for tonight ! _________________ Phil |
swing Pocket GPS Verifier
Posted: Thu May 17, 2007 5:01 pm Post subject: |
marksnsparks wrote: | Wonder if the answer is 257? | You are on v3.90, which no longer crashes with over 257 categories, but it is possible that instead of crashing, it simply stops displaying the bitmaps...
Either that or for some reason it's hitting a corrupt bitmap and not coping beyond that point. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Thu May 17, 2007 8:27 pm Post subject: |
swing, as far as I know version 3.90 is the latest update for the 310. It seems to be able to cope with about 290 categories + speed cameras. Thats about 82000 poi's. Seems better to load the cameras on the nuvi and leave the rest on the SD card. _________________ _________________
V9 Maps
Audio version 2.30
GPS v3.00
Posted: Fri May 18, 2007 8:38 am Post subject: |
marksnsparks wrote: | swing, as far as I know version 3.90 is the latest update for the 310. | Indeed it is.
Quote: | It seems to be able to cope with about 290 categories + speed cameras. | Good to know - it's worth pointing out to others that all previous Nuvi 3x0 firmwares, and (currently) the latest 660 firmware still has the 257 category limit. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
perussell Frequent Visitor
Posted: Fri May 25, 2007 9:56 am Post subject: |
OK, so I am trying to download the app as suggested by Philpugh in another thread so that I can access voice warnings etc but each time I try and run the saved file I am encountering a problem and it won't install properly. Any suggestions, it saves to my hard drive Ok but that's as far as I can get, as soon as I try and run the install the camera icon appears in my task bar, and I then get a message saying the application has had to close. The camera icon in my task bar disappears as soon as I hover over it
I should add that I am running XP Pro with IE6
I have POI version 2.4.1.
Having read other messages I note some people have had to do a system restore. As I understand it that deletes any and all documents post the restore date so that is not an option for me since I use this as a work PC |
Posted: Wed May 30, 2007 8:14 pm Post subject: |
Version 2.0.0.1 beta is now available :D
Very minor change - generated POI filenames now have the speed as a word instead of a number (ie: PocketGPS_UK_Thirty instead of PocketGPS_UK_30).
This is to stop some versions of POI Loader from being too clever for their own good, and overriding the warnings settings based on the filename.
The example voice warnings - http://tinyurl.com/2rvqx6 - have also been updated accordingly.
Enjoy! ;) |
shanedunn Occasional Visitor
Posted: Thu May 31, 2007 11:10 am Post subject: |
This new beta keeps telling me "updates are ready for installing, even though I have POI Loader to uodate my Garmin Nuvi. |
Posted: Thu May 31, 2007 11:17 am Post subject: |
A new database came out yesterday. Once Camera Manager has downloaded the updates you need to install them to your Nuvi with POILoader. |
Posted: Thu May 31, 2007 11:45 am Post subject: |
Correct, an update did come out yesterday and I have used camera manager to download it and POI to install it and am getting the message mentioned in my last post. Thanks for the thought though :D |
Posted: Thu May 31, 2007 1:33 pm Post subject: |
ah.... |
GJF Frequent Visitor
Posted: Thu May 31, 2007 1:45 pm Post subject: |
keystrokes wrote: | .........Mine is a clean install of Vista (Home Premium), The security has been adjusted, but only for other things, so it could affect this.
IE7 Protected mode OFF
User Control Account OFF
Windows Firewall OFF........... |
Does anyone have any other ideas than having all the above settings OFF, to get Windows Vista working with Camera Manager please? _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver |
