DaveyBoy55 Occasional Visitor
Posted: Tue May 29, 2007 8:14 pm Post subject: TomTom Speed Cameras On Ipaq 3950 |
Hi Everyone I Have Installed The Speed Camera Pois In My Western Europe Maps Folder But I Can Not See Them In TomTom On My Device. When I'm Hooked Up To My Pc With TomTom Home Running All Pois And The Camera Are In The POI's List. I Also Have Speed Camera's In The GB Major Rods W/E Folder Could This Be The Problem?
Help Much Appreciated
Regards
Dave Beard |
Posted: Tue May 29, 2007 8:21 pm Post subject: |
Change preferences/ Manage Maps/ Switch maps, select the map you want to be current and the POI files should appear - Mike |
Posted: Tue May 29, 2007 8:34 pm Post subject: |
Hi Ive Removed Camera's From GB Map And Selected W/E Map But Still All My POI's Are There Except The Speed Camera! |
Posted: Tue May 29, 2007 8:39 pm Post subject: |
OK the other idea is the POI limit, how many files ending with .ov2 are contained in the map folder, if you are using TomTom version 5 software the limit is 39, if you are using version 6 software the limit is 100.
If you exceed the limit applicable to the software you have loaded to the device you will find some POI files will be visible in Windows Explorer but not available for selection on the device - reduce the numbers of POI you have installed below the limit is the only answer - Mike |
Posted: Wed May 30, 2007 12:08 am Post subject: |
Hi Thanks Mike I Just Removed Over 200 Poi's And Now Have About 90 And Now I Can See All The Camera's.
Regards
Dave Beard |
