Henry Occasional Visitor
Posted: Sat May 26, 2007 11:36 pm Post subject: Backup Program for TT5 and XdaII (Pocket PC) |
Hi, sorry this is not strictly a TomTom post, but related to it and PDA’s in general.
Mt PDA XdaII is running TomTom 5 with no problems; the UK map is stored on a 1GB SD card and the TT application runs off the the PDA main memory.
All is well with the world, but every now and again I’m a bit stupid and let the battery go flat… I must have re-installed TT at least five times now…
Now this is not normally a problem as I just drive home, sync my PDA to my PC and re-load the TT application from my DVD’s. But shortly I’m off to the USA on a driving holiday and I just know what’s going to happen… and I won’t have a PC with me…
Does anyone know of a PDA “backup program” which will take a true copy of my PDA’s volatile main memory (bearing in mind that I guess some programs like the diary will always be running) and allow me to store the backup image onto my SD card (I’ve plenty of free space for this).
Then if (when) the worst happens, and I have a factory reset PDA, I need a way of running a restore program (I assume I can also keep this program on the SD card) to put everything back in the PDA main memory.
Sorry it’s a bit long winded, but hope it makes sense.
Thanks Henry |
JockTamsonsBairn Lifetime Member
Joined: Jan 10, 2004 Posts: 2777 Location: Bonnie Scotland (West Central)
Posted: Sun May 27, 2007 1:04 am Post subject: Re: Backup Program for TT5 and XdaII (Pocket PC) |
Henry wrote: | Does anyone know of a PDA “backup program” which will take a true copy of my PDA’s volatile main memory (bearing in mind that I guess some programs like the diary will always be running) and allow me to store the backup image onto my SD card (I’ve plenty of free space for this).
| Have a look for Sprite Backup. One of the options, as well as backing up to your PC, is to produce a self extracting file, that you can store on the PDA or SD Card, that will restore your PDA. You hardware reset, execute the file and Hey Presto! back to where you started!! _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
widu Occasional Visitor
Posted: Sun May 27, 2007 6:48 am Post subject: |
I use SPB Back up as it integrates with my other SPB software and can be found here
EDIT Once - Mike Alder - It is against the forum rules to post links to illegal software, please refrain from such behaviour. _________________ Device: Co-Pilot (Android)
Skoda Columbus |
Posted: Sun May 27, 2007 7:51 am Post subject: |
I would also carry the CAB files on your memory card in a folder, these are the installation files for your software so if everything goes wrong you can still install applications such as TomTom.
One other tip, before copying the CAB files to your PDA's memory card set them as read only in windows explorer, otherwise the first time you use them they will erase themselves after the installation - Mike |
Posted: Sun May 27, 2007 8:06 am Post subject: |
Lots of good advise and a very speedy response (as always)
Thanks for all you help, Henry |
Posted: Sun May 27, 2007 11:20 am Post subject: |
widu wrote: | I use SPB Back up as it integrates with my other SPB software and can be found here | From the Forum Rules & Guidelines For Use Quote: | • Discussion of illegal activities such as software piracy and other intellectual property violations are not allowed. |
Posted: Sun May 27, 2007 12:48 pm Post subject: |
EDIT Once - Mike Alder - It is against the forum rules to post links to illegal software, please refrain from such behaviour. | The correct link is here. _________________ Jock
Posted: Sun May 27, 2007 9:33 pm Post subject: |
BGF wrote: | widu wrote: | I use SPB Back up as it integrates with my other SPB software and can be found here
EDIT Once - Mike Alder - It is against the forum rules to post links to illegal software, please refrain from such behaviour. | The correct link is here. |
Thank you for pointing that out, however it is not true, the only rule in the forum with regard to "illegal" software is the DISCUSSION of it, there are not rules about links or the posting of it, merely to discussion. That particular link was to a site and not to any software. On that site is both freeware, shareware and retail software. If you want tighter control write better rules. End of. _________________ Device: Co-Pilot (Android)
Skoda Columbus |
Trevor1234 Frequent Visitor
Joined: Apr 30, 2005 Posts: 810 Location: Milton Keynes
Posted: Sun May 27, 2007 10:22 pm Post subject: |
Hi Henry
Sprite Backup only costs a few quid and works perfectly. I can, if I wished, completely erase everything (or give a hard reset) with the full knowledge that all is not lost. Sprite Backup will restore everything as it was at the point of the last backup. By everything I mean everything including the Bluetooth settings, Tomtom, files and, well, everything. I know that it works. Go for it. _________________ Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G |
