Pocket GPS World :: View topic - TomTom POI Question
TomTom POI Question
Das_EEjit
PostPosted: Wed May 16, 2007 10:43 pm    Post subject: TomTom POI Question Reply with quote
I've been playing with POI's on my TomTom after downloading and editing some files, and I've noticed something strange.
I have downloaded a file for National Trust properties and one for Aviation Museums, amongst others. When I look at the NT properties on my TT, it lists each property by name, so far so good.
When I look at the aviation museums, they are all listed as Aviation Museum (unnamed), even though ther are named in the OV2 file.
Can anyone explain why that should be and how I correct the problem?
RQ
PostPosted: Thu May 17, 2007 5:41 am    Post subject: Reply with quote
If you can tell us where you got the poi files from then we can try and replicate your problem.
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
Das_EEjit
PostPosted: Thu May 17, 2007 8:47 am    Post subject: Reply with quote
RQ
I got the file from here
http://www.pocketgpsworld.com/modules.php?name=POIs
It's under Special Interest, Aviation Museums
Oldboy
PostPosted: Thu May 17, 2007 9:15 am    Post subject: Re: TomTom POI Question Reply with quote
Is this with something like POIEdit?
Are you doing something with the OV2 File when you are Copying to the TT?
Das_EEjit
PostPosted: Thu May 17, 2007 9:47 am    Post subject: Reply with quote
I used dumpov2.exe, (from TomTom),to dump the file from OV2 format to text, then used makeov2.exe to generate the new OV2 file after editing.
I've modified a couple of files using the same method, the aviation museum one is the only one I'm having trouble with
Steve
Das_EEjit
PostPosted: Thu May 17, 2007 9:51 am    Post subject: Reply with quote
OOps
When I copy the file back to TT, i'm doing nothing special. I'm just following the instructions on this page
http://www.tomtom.com/support/ce/support/nav_poi.php
Regards
Steve
Oldboy
PostPosted: Thu May 17, 2007 1:23 pm    Post subject: Reply with quote
Why do you need to Edit the OV2 Question
Das_EEjit
PostPosted: Thu May 17, 2007 11:06 pm    Post subject: Reply with quote
I edited the data because it was wrong.
RQ
PostPosted: Fri May 18, 2007 6:01 am    Post subject: Reply with quote
If you use poiedit (free) the you don't have to convert to text and save with another programme.
It just opens the file up in its current format, you can then edit the data as you wish (or add, delete etc) and then save the file. It seems simpler than the TT programme.
Try again with poiedit and see if that helps.
RQ
Das_EEjit
PostPosted: Mon May 21, 2007 10:39 am    Post subject: Reply with quote
Sorry for the delay in answering, rather a busy weekend.
I checked the file with POIEDIT as suggested, and there were no names in the file, strange, the other files I edited were all OK.
I've now resolved the rpoblem, and changed the location.
I've also made some changes via this web site, local knowledge is a wonderful thing.
Thanks for all your help
Regards
Steve
22.071 (03 Jul 24)
