Pocket GPS World :: View topic - which map will be better?
ponti
PostPosted: Tue May 15, 2007 3:14 pm    Post subject: which map will be better? Reply with quote
actually i use uk map version 650 with tomtom 6.010
i have also uk plus 632 map. what is the difference between normal map and plus map? and will this 632 plus map work with my 6.010 tomtom?
cheers for any help Smile
philpugh
PostPosted: Tue May 15, 2007 4:02 pm    Post subject: Reply with quote
The Plus map has the major roads of Europe included - never really saw the point in it as it's the navigating in and around towns or on the back roads where you are really likely to get lost as the main routes are generally very well signposted.
I guess it does allow you to buy a separate country and allow you to do psuedo routing door to door. At least you could get into the country (e.g. France) then swap maps at a convenient journey stop and get the detailed directions to your destination - but MOWE (full Western Europe) was never that much more in price and allowed proper door-to-door routing.
There's a pointer to a matrix showing what works with what in the sticky area of this forum.
Phil
Border_Collie
PostPosted: Tue May 15, 2007 5:55 pm    Post subject: Reply with quote
As you already have the GB and GB plus maps it would, as philpugh says, be better to purchase Western European maps.
If on the other hand you will only ever travel to one other country, say France, then it is slightly cheaper to purchase the France plus map.
All you'll need for cross country routing is the GB map and the France plus map.
Before setting off select the France plus map and set a destination. You'll be guided over the major roads in GB and on entering France you will have street level.
Similar if the only country you will travel to is Italy, purchase the Italy plus map. Select the Italy plus map, set destination and you'll be guided over the major roads of Europe to the Italian border where you will have street level.
Having said all that, it probably would be best to get the Western Europe maps, just in case you need them at a later date.
vroomfondel
PostPosted: Fri May 18, 2007 8:33 pm    Post subject: Reply with quote
But avoid the WE_v675.1409 because as discussed in another thread its pants.
22.064 (26 Jun 24)
