Pocket GPS World :: View topic - nuvi310 and car speakers
rabtt
PostPosted: Mon May 14, 2007 7:26 pm    Post subject: nuvi310 and car speakers Reply with quote
Ermm Rolling Eyes am I right in saying that I can play my MP3 music files thru my car speakers using my nuvi 310? If so, what extra hardware do I need to do this?
ps - it's great how playing music thru its built-in speaker, the music stops to allow the 310 to make an annoucement and then resumes play .. 8)
PostPosted: Mon May 14, 2007 7:45 pm    Post subject: Reply with quote
Have a read through my post in This Thread which details a few options for connecting the Nuvi to the car deck, it does pause the music playing from the Nuvi when issuing warnings or navigation - works very well in use though, not too hot from the inbuilt speaker though - Mike
rabtt
PostPosted: Mon May 14, 2007 7:55 pm    Post subject: Reply with quote
Mike mate, you are a star First As usual, my 'search' technique requires some fine tuning (pun) - I'd have never found it under 'motorhome' anyway!! Laughing Laughing
my car is a 2002 Audi so I'm pretty optimistic that it'll have either a 3.5mm aux input or RCA (hey, I sound like I know what I'm talking about Laughing ).
OK next (a little off-topic) but could I take a spare 12V nuvi charger, cut off the cigarette socket and hard wire it to a constant +12V supply behind the dash leaving the mini USB available for hooking up every time I jump in my car?
PostPosted: Mon May 14, 2007 8:14 pm    Post subject: Reply with quote
I doubt that to be honest Wink but I might save you some considerable expence with the following part of this post.
Please do not do this as you will fry the device, what is better is to fit an aux charger socket behind the dash and plug the Nuvi charger in to the socket as supplied, the actual plug contains a voltage regulator circuit that drops the voltage from the nominal 13,8V of the car to the 5V the Nuvi requires.
Something like This with the Nuvi chager cable plugged in to it will be fine if hidden behind the dash, you can cut the plug off the Maplins addapter, but NOT the Nuvi cable, connect the free cable end to a fused supply (radio feeder cable is probably easiest) - centre pin is Pos, once the charger is inserted to the socket and working tape the whole assemby up to prevent it from comming loose behind the trim.
Finally a word of caution, modern cars are fitted with explosive devices, air bags etc, they are located behind the dash so please make sure you know what you are doing - Mike
rabtt
PostPosted: Mon May 14, 2007 11:46 pm    Post subject: Reply with quote
Hi Mike
I hear you loud'n'clear on that last part - in the Fire Service so have seen some close shaves with airbags etc! Surprised
I now understand what you mean re cutting off the plug on the NUVI adaptor, however does the same not go for the MAPLIN one? If not, I was thinking of then cutting the plug off the MAPLIN and splicing the wires into the feed for the car cigarette lighter behind the dash, thus allowing me to retain the standard 12V car socket but have an extrat 1 (or 2) behind the dash..! Question
swing
PostPosted: Tue May 15, 2007 7:03 am    Post subject: Reply with quote
The same does not apply to the Maplin device as it starts with 12v and ends with 12v...
If you don't like the Maplin unit, Maplin also sell some individual components, allowing you to create your own (although it may work out more expensive).
Please don't be offended if I do not reply to a PM - please ask questions via the forums.
PostPosted: Tue May 15, 2007 7:09 am    Post subject: Reply with quote
The power addapter for the Nuvi contains the voltage regulator which is why you shouldn't remove it. The Maplins two way extension addaptor is simply a plug containing no regulation etc. so it quite simple to remove that one from the wires and connect direct to a fused outlet - Mike
rabtt
PostPosted: Tue May 15, 2007 8:09 am    Post subject: Reply with quote
..makes sense. Thanks guys! Wink
22.105 (30 Oct 24)
