Pocket GPS World :: View topic - Current BT GPS with wired NMEA output?
Pc-Mobile
PostPosted: Fri May 11, 2007 3:39 am    Post subject: Current BT GPS with wired NMEA output? Reply with quote
Apart from the Holux lines, what other BT GPS (Sirf III or MTK) have wired output as well?
Holux models wired output is 38400 which is a pain. We need one with 4800 output.
We are not so much after a BT GPS but a small high performance wired GPS with it own battery. It seems that only BT GPS has its own battery. Other non-BT wired GPS tend to need external power so a BT GPS with wired output fits the bill.
Pc-Mobile
http://pc-mobile.net/gps.htm
philpugh
PostPosted: Fri May 11, 2007 9:09 am    Post subject: Reply with quote
Haicom do devices with SiRF III chips that can have a serial output. For some you have to buy a 'slipper' for the device others come supplied with the correct cables. The 405BT springs to mind - you can get a cable to give you serial NMEA output as well as BlueTooth.
Have a look at http://www.haicom.com.tw/ for info
I would expect that you could lower the speed of the Holux device somehow. The NMEA spec specifically mentions 4800 bps (baud / whatever) for compatibility between devices.
Phil
Pc-Mobile
PostPosted: Fri May 11, 2007 6:20 pm    Post subject: Reply with quote
Thank you.
I had a look at Hiacom's site.
It does seem to be suitable.
But it is ugly/big!
Battery life is poor (8 hours).
Seems more expensive than competitors.
But I will certainly look into it if I cannot find any other.
Pc-Mobile
22.064 (26 Jun 24)
