voice_of_reason Regular Visitor
Posted: Thu May 10, 2007 1:18 pm Post subject: TomTom ONE backup question - is EVERYTHING on the SD card? |
If I backup my TomTom ONE by copying the contents of the SD card (including hidden files and folders), am I actually backing up EVERYTHING on the unit?
Or does the unit have a ROM or something similar where the application is installed?
Would I be safer backing it up using the option in TomTom HOME, or does that achieve exactly the same thing as copying the contents of the SD card manually?
Cheers! |
nazimyounis Regular Visitor
Posted: Thu May 10, 2007 2:30 pm Post subject: |
I backed mine up manually and via TomTom Home....i've also done a restore on a different memory card both manually and via TomTom home both have worked for me.
Hope that helps
Regards
Nazim _________________ TomTom ONE V2 (GB) Downloaded Europe Maps
Transcend 2GB Hi-Speed 150X SD card
ex - TOMTOM Nokia N95
ex - TOMTOM GO 700
ex - TOMTOM Navigator 5 on XDA IIi
ex - TOMTOM Navigator 3 on XDA II
ex - TOMTOM Navigator 3 on XDA |
Posted: Thu May 10, 2007 2:41 pm Post subject: |
OK, thanks. The only reason I ask is that, with a PDA, you tend to have most stuff on the SD card, but the application installed to the unit. So I just wondered if the TomTom ONE works in a similar way?
Having said that, there are a lot more files and folders on the ONE's SD card than I had on my old PDA, so I guess the application itself could be fully installed on the SD card too. |
Oldboy Pocket GPS Moderator
Posted: Thu May 10, 2007 3:12 pm Post subject: |
voice_of_reason wrote: | so I guess the application itself could be fully installed on the SD card too. | Everything you need to get it working is on the SD Card.
This is why it takes a little longer to start, after a Reset, due to rebooting the program from the SD Card. _________________ Richard
Posted: Thu May 10, 2007 3:23 pm Post subject: |
Thanks for that Oldboy! I guess this is what happens after you take out and re-insert the SD card too? It comes up with the TomTom splash screen and takes quite a bit longer to load after you first re-insert the card. |
