BAVC10 Lifetime Member
Posted: Mon May 07, 2007 8:59 pm Post subject: Nuvi 360/370/310 Firmware 3.90 |
Garmin released ver 3.90 on May 2nd - sure it wasn't there yesterday
Change History
Changes made from version 3.80 to 3.90:
Updated Lithuanian text translations
Corrected issue that could cause the unit to shutdown during some searches for cities and streets
Corrected issue that could prevent proper startup when custom POI files contain a large number of bitmaps
Changes made from version 3.60 to 3.80:
Added support for Brazilian Portuguese, Bulgarian, Lithuanian, Romanian, and Serbian pre-recorded voices. Download voices using WebUpdater.
https://buy.garmin.com/shop/store/downloadsDetails.jsp?id=1847&product=010-00538-00&cID=134&pID=6291 |
swing Pocket GPS Verifier
Joined: Nov 04, 2003 Posts: 2225 Location: Bedfordshire, UK
Posted: Mon May 07, 2007 9:04 pm Post subject: Re: Nuvi 360/370/310 Firmware 3.90 |
BAVC10 wrote: | Corrected issue that could prevent proper startup when custom POI files contain a large number of bitmaps | I wonder if this was the cause of the 257 category limit... If so, I wonder if it's now fixed, or just a higher limit - anyone fancy trying to see? (MaFt...??) _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Mon May 07, 2007 10:09 pm Post subject: |
i'll give it a shot... actually, seeing as it mentions the issue is with bmp's i might try loading say, 50 poi files without any bmp's to see if i can kill it!
i'll try tomorrow ;)
MaFt |
Posted: Mon May 07, 2007 10:18 pm Post subject: |
50 - I wonder if you meant 500... :P
Be interesting to see though - given you've got the RGN restore file for your unit, it might be interesting to try 500 categories with no BMPs (should be ok), 500 categories with BMPs (should crash), restore the unit, and then try the new firmware with both sets again (both should be ok)...
Definitely interested to hear the results...
Of course, there is not yet an equivalent 6x0 firmware update (or 300/350 for that matter). _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
Posted: Tue May 08, 2007 8:55 am Post subject: |
i stupidly went and updated the firmware without first testing 500 without bmp's so can't report on that one...
however, firmware 3.90: loaded up 436 poi categories with bmp's and....
EVERYTHING BOOTS UP FINE! |
Posted: Tue May 08, 2007 10:12 am Post subject: |
Well, you could downgrade just to test it, but to be honest, it's nice to see the problem fixed. Given this website was one of the main causes of the problems (due to the amount of POIs available for download), it's nice to see Garmin listened and have fixed the problem. _________________ Please don't be offended if I do not reply to a PM - please ask questions via the forums. |
marksnsparks Occasional Visitor
Posted: Tue May 08, 2007 9:26 pm Post subject: |
not sure if it's just my imagineation but the nuvi 310 seems to respond to keystrokes a little quicker after updating from v3.6 to v3.9 _________________ _________________
Garmin Nuvi 310 - Version 4.70 Firmware.
V9 Maps
Audio version 2.30
GTM12 - Version 4.80 Firmware
GPS v3.00
bluetooth software version 3.10 |
Posted: Tue May 08, 2007 9:44 pm Post subject: |
they haven't sorted out the mapping lag though like they did with the latest i3 firmware... |
petepda Occasional Visitor
Posted: Wed May 09, 2007 7:53 am Post subject: |
MaFt wrote: | they haven't sorted out the mapping lag though like they did with the latest i3 firmware... |
Is this where the maps lag behind where you actually are on the road by 50 yards or so? I've noticed this on my Nuvi and it's really annoying when you're using it in passive mode, i.e. not on a planned route. Surely the camera warnings could be late if the unit is way behind where you are? I live in hope that they'll sort this on the Nuvi as i'm sure my previous TomTom didn't suffer from this.
Thanks for the tip of the new software though - downloaded last night, not that any of the updates particularly affected me. |
Posted: Wed May 09, 2007 8:50 am Post subject: |
petepda - i've found that the warnings and notification of the 'next street' are spot on, it's just the actual map display that is behind
MaFt |
Posted: Wed May 09, 2007 12:42 pm Post subject: |
MaFt wrote: | petepda - i've found that the warnings and notification of the 'next street' are spot on, it's just the actual map display that is behind
MaFt |
Oh right - hadn't realised this.
I wrote to Garmin this morning about this issue to ask if they have a fix in the pipeline. I'll let you know the response - if i get one. |
Posted: Sun May 13, 2007 7:46 pm Post subject: |
Just for the record, i got a response from Garmin that has solved the problem - see below:
A master reset will resolve this. To master reset the unit please try the following;
with the device switched off, hold and press the top right hand corner of the touch screen, power the unit on in the usual way, as soon as the unit powers up, release the power button, but not the screen. The message 'Do you really want to erase all user data' will appear. Tap yes and then reset the device as prompted. wait for a gps fix before setting off on your journey.
This has happened due to no fault of yours. The unit has collected corrupt information from the satellites. This can happen occasionally if the signal is blocked by tall buildings etc. however this is not common. |
Posted: Mon May 14, 2007 9:57 am Post subject: |
petepda wrote: | however this is not common. |
ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
yes it is! |
Guffnuts Occasional Visitor
Posted: Mon May 14, 2007 12:43 pm Post subject: |
Am I right to assume that the master reset will delete all saved favs, POI etc? |
Posted: Mon May 14, 2007 12:54 pm Post subject: |
Do i detect some irony in Garmin's statement then??!! Is this problem unique to Garmin, or do all Sat Navs suffer from it?
Guffnuts - in my case, it didn't erase any of my favourites or installed POIs. |
