Posted: Fri Apr 13, 2007 9:17 am Post subject:
Partly my mistake, when rushkins asked for OGG files I assumed that's what the DS used whereas I should have known they didn't! _________________ Darren Griffin
Joined: Aug 31, 2005 Posts: 15388 Location: Bradford, West Yorkshire
Posted: Sat Apr 14, 2007 12:36 am Post subject:
blimey, you lot have been busy while i was away!!
regarding redlight cameras - these ARE in the PGPSW download - open the file in notepad and do a search for ;10; as category 10 is the redlight cameras.
as for blackspots then it would mean adding them to the main database at pgpsw however at the moment it is a speed camera database and therefore does not include the blackspots data.
I went through a red light camera in Croydon last week and had no warning, so presumed it wasn't working - as the DS unit would normally speak "warning red light camera", maybe the unit was playing up.
As for the blackspots again the DS unit speaks "warning blackspot" so I thought it would be usefull to use the facility as it was there.
It is definitely useful to curb speeding in a dangerous area, i used to respond to it all the time, as i felt that as there had been more than two/three deaths in that spot there was a reason to be on guard.
Maybe it would be useful for others on pgpsw as it is often surprising where a reduction in speed could save a life, particularly when it warns on a innocent looking stretch of road - not sure about road speeds but just a warning would help.
Could you please inform me if it would it be feasable to just add the blackspots to the DS database, or does this make your work more complicated than it already is? _________________ TomTom Go 60
Garmin Nüvi 660, Firmware v4.90
Drive-Smart GPS with Loader v1.4.16
HTC Advantage X7500 MS 6.1 Tchart Speed Sentry
Satmap Active 10, Software v1.16
Fuzion 32 HUD Bluetooth GPS receiver
Will have to remember where it was now, but back again in a couple of weeks. _________________ TomTom Go 60
Posted: Mon Apr 16, 2007 12:14 am Post subject:
highly doubtful at the moment! there's enough work with just the speed cameras! as for the database, every unit uses the same database, we just export it in different formats so if blackspots are there for one, they're there for everyone,
also, how do you define a blackspot? what would be required for a blackspot to no longer be a blackspot and be removed from database? if someone submits a new blackspot, how do you confirm it? etc etc etc
That's cool 8)
Sorry MaFt, until you informed us had no idea of your work load.
Didn't realise that either, I wrongly thought that each type of unit had it's own custom made database.
Just thought that as the DS unit had the facility to use blackspots it was a shame not to use it.
The Accident Blackspots program determines locations where two or more traffic accidents have occurred, based on a set of police accident records as input.
So once a blackspot always a blackspot, it can only get worse by more accidents or deaths, so will never be removed.
All blackspots are determined by the relevant County Council Road Safety Dept and published County by County.
I will extract those already known from the DS site and add to the pgpsw DS database each month when I’ve worked out how to do it.
Here is a list according to a British Army Safety website of the UK’s most dangerous roads, judged by number of deaths per billion km travelled on the road by the European Road Assessment Programme (EuroRAP) - spare a thought for safety if you use these regularly:
A 537 Macclesfield to Buxton - a route over the Peak District popular with motorcyclists.
A12 Romford to the M25 - an overloaded and often congested route to the M25.
A4137 west of Ross on Wye - the main north south route from Hereford to South Wales.
A628 near Penistone - an east-west route over the north of the Peak District.
A1001 Hatfield - providing parallel links to the A1M with access to Hatfield, St Albans and Welwyn.
A534 Welsh boundary to Nantwich - a ‘cut through’ route to and from North Wales avoiding Chester (A55 and A5).
A533 to Runcorn - part of the ring road surrounding Runcorn, a route to the Mersey Bridge and to the A56 and M56.
A682 to M65 J13 - A65 Long Preston - route into the hills, along the Ribble valley and towards the Yorkshire Dales.
A5 Daventry to Rugby - old Roman road, heavily-used, running parallel to the M1.
I have been running the PGPSW database alongside the DS database and I have been having the following problems,
the DS tells me that mobile sites are Gatsos and mobiles or just Gatsos even though they are mobile sites and it tells me I am going to fast even though I am well under the limit and also not all speed limits are recognised when there is a camera site.
I wish to use the two databases together if possible but I do seem to have some form of conflict, can anyone advise?
Hope this makes sense.
There was a fault in the PGPS database, so download the latest and try again.
The PGPS database may have some speed limit errors so log any you find and use the submit function which can be found under the Speed Camera section. _________________ Wayne
Posted: Thu May 03, 2007 1:15 am Post subject:
Snoopydog wrote:
Snoopydog
if you could try make a note of where these anomalies are then locate them on the map and let me know the camera ID number (eg GATSO:1234@30 etc) then i can take a look
These are some of the Cameras that I have had problems with.
I am running the latest PGPSW database for the DS along with the last DS database. (both together as instructions on download help)
They are all described as Gatsos and I am told that even though I am well under the limit I am still going to fast e.g. the mobile 30 will be a Gatso and the speed limit is 20 not 30mph.
Am I having conflict between the two databases as I do not believe I have changed any settings on the DS so any help etc will be appreciated.
Regards
Snoopydog
Mobile:5637@30
Mobile:23861@40
Mobile:6040@Unknown This Is 40 limit)
Mobile:5631@40
Mobile:17313@30
Mobile:29864@30
Gatso:3058@30
Gatso:2283@50
Gatso:1075@50
Mobile:29721@30
Mobile:23257@50
