Pocket GPS World :: View topic - What size memory card for I3
VEGG
PostPosted: Thu May 03, 2007 4:03 pm    Post subject: What size memory card for I3 Reply with quote
I have an i3 with the transflash memory card what size card can i go up to ? without any problems will 1gb be ok . Is it just the maps stored on the card ?
VEGG
PostPosted: Fri May 04, 2007 2:36 pm    Post subject: Reply with quote
Anyone ?
snowboardcriminal
PostPosted: Fri May 04, 2007 2:46 pm    Post subject: Reply with quote
Maximum is 1Gb i believe.
Don't eat yellow snow
i3, on the middle of the dash, works just fine!
There are things that I know and you don't know, there are things that you know that i don't know, but always remember there is much that we both don't know.
PostPosted: Fri May 04, 2007 3:10 pm    Post subject: Reply with quote
Just beware if your device was supplied with the maps installed to the memory card then they are locked to that specific card, you cannot simply copy the cards contents to another card and expect it to work - it won't.
If you are loading new maps fair enough, if all you need is to install some POI to the card there should be sufficient space on the existing card, for later units supplied with the maps installed to internal memory you can buy a card for installing POI to but don't waste your cash on anything as large as 1GB, POI files are very small - your device is limited to 85 custom POI categories so I would think even a 32MB card (if such a size exists would suffice) - Mike
VEGG
PostPosted: Fri May 04, 2007 4:11 pm    Post subject: Reply with quote
Forgot to say i have had the free map upgrade disk and want to load more onto my i3 so can i just buy a bigger card and load them on Embarassed
PostPosted: Fri May 04, 2007 5:25 pm    Post subject: Reply with quote
In that case yes as you will have the codes to activate the new map, I only mentioned the issues surrounding larger cards as we often get people trying to transfer the old card to a new card and then they find it won't work - Mike
Nick_Russell
PostPosted: Fri May 04, 2007 5:34 pm    Post subject: Re: What size memory card for I3 Reply with quote
1GB according to Kingston. See here...
http://www.smcdirect.com/kingston.asp
Nick Russell
Garmin nüvi 3590LM
SW v4.60, Audio v1.50, GTM v5.30, GPS v3.00, Bluetooth v3.40
City Navigator Europe NT 2008. GarminPOI Loader 2.5.2
poppycat
PostPosted: Sat May 05, 2007 10:27 am    Post subject: Reply with quote
Garmin told me to get a 2gb transflash card to update maps to V9. Thats what I got anyhow and just updating the maps as we speak
sunstrip_steve
PostPosted: Sat May 05, 2007 10:41 am    Post subject: Reply with quote
Was that for an i3 though? I understood that 1 gb was the maximum supported, and that the bigger the card the slower the device worked.
Maybe this is myth - anyone?
poppycat
PostPosted: Sat May 05, 2007 12:14 pm    Post subject: Reply with quote
Seems to be okay with 2gb card, I just installed the V9 maps and it took about 45 mins to do the whole lot. When I ran garmin I noticed in maps it has v8 and V9 so I disabled the v8 by unchecking the checkbox.
It was Garmin that told me to get a 2gb card.
I do have the garmin i3 that didnt come with a transcard, maps were built in.
sunstrip_steve
PostPosted: Sat May 05, 2007 1:50 pm    Post subject: Reply with quote
Wonder if its different between the 2 types of unit? I guess its worth £17 to find out. Is that enough for the whole of Europe then?
Anita
PostPosted: Sat May 05, 2007 2:29 pm    Post subject: Reply with quote
An email I received from Garmin about updating to v9 maps said:
". . . the i3 can hold on its internal memory/micro sd card an update for the UK and Ireland maps, if more is required for example, some European mapping you may need a larger card and the i3 is compatible with up to a 1GB micro sd card."
I was able to fit nearly all of Western Europe on a 1GB card, which is more than I shall ever need.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
poppycat
PostPosted: Sat May 05, 2007 10:55 pm    Post subject: Reply with quote
I selected the whole map that came on the dvd, and exported to the i3, I think it took about 1.2gb in all.
I got the card from Play.com think it was £14.99 with postage
http://www.play.com/Mobiles/Mobile/4-/3251313/Sandisk_2GB_Micro_SD_Card/Product.html
andymh
PostPosted: Sat May 12, 2007 10:01 am    Post subject: i3 Memory Reply with quote
I3 will take a 2GB card, £18 on Net. Loaded the full V9 mapping, everything runs ok and camera sites.
VEGG
PostPosted: Sun May 13, 2007 2:08 pm    Post subject: Reply with quote
Just ordered a 2gb card from play.com for £15 delivered
