Phileasfrog Occasional Visitor
Posted: Wed May 02, 2007 4:12 pm Post subject: Whether or not to go for latest map - TomTom One Europe?? |
After some debate with TomTom they have now agreed to provide an update to the map via the PLUS menu of TomTom Home - I purchased the unit on 17 April. - So good news so far!
However I have noted with some concern various comments about the apparent removal of certain data / detail from the new version - presumably to keep it below the 1Gb limit. I don't drive in Central London and thus the new Congestion Charge mapping is of no interest to me.
Is there an overall consensus now as to whether it is worth the update, or should I just stick with what I have - v.660.1256??
Any thoughts gratefully received! |
entwood Regular Visitor
Posted: Wed May 02, 2007 4:37 pm Post subject: |
I cannot fully answer the question, as much becomes personal opinion and preferences, but I have been watching comments in this forum, and a similar one elsewhere, and I have formed the following opinions - perhaps others might like to add theirs:
1. Western Europe - Teleatlas 6.6 build 1219 - Some countries deleted from the original 6.25 versions. Speed warnings introduced but many in error, several errors to maps.
2. Western Europe - NavTeq 6.6 build 1256 - Also has some countries deleted but appears to have fewer mapping errors and fewer speed limit errors.
3. Western Europe - Teleatlas 6.75 - 1 Gb version - Much "background" data removed ( forests rivers etc etc) to enable it to fit on a 1Gb card - mapping data similar to Navteq 6.6
4. Western & Central Europe - Teleatlas 6.75 - 1.67 Gb version - Background info retained, some reports of errors in UK mapping but also reports of improved French mapping.
Now my interpretation of what others are posting may well be wrong, but this is how I read the situation at the moment... confused ?? I certainly am... none of the available maps seem to be "error free", and there are conflicting reports about those errors !!
With luck (?) this thread may grow with other comparative results on which decisions can be made ... I'm hanging on for a while !!
Entwood |
Posted: Wed May 02, 2007 5:01 pm Post subject: |
Thanks for the useful response and I can understand your "wait and see" stance. However, you refer to some countries having been removed from v660.1256. I wasn't aware of this and would be interested if you have more specific info. |
Andy_P Pocket GPS Moderator
Posted: Wed May 02, 2007 5:56 pm Post subject: |
Poland and the Czech Republic were on the Go700 but were removed in all Western Europe maps available since (and the 710) |
Robin2 Lifetime Member
Posted: Wed May 02, 2007 8:15 pm Post subject: |
Why not buy a larger card (dirt cheap now), change the name of your original set of maps and have both. You can then make up your own mind which is better
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
ianb11 Lifetime Member
Posted: Wed May 02, 2007 10:25 pm Post subject: |
Robin2 wrote: | Why not buy a larger card (dirt cheap now), change the name of your original set of maps and have both. You can then make up your own mind which is better
Robin |
How do you do this?
I'm in the same boat as Phileasfrog in that I have managed to get a free upgrade to the maps from TomTom & I can't decide whether to get them or not. |
DennisN Tired Old Man
Posted: Wed May 02, 2007 10:59 pm Post subject: |
Get your free download "updated" map - you'll not get much more free from TT in the future!!. Using TT Home, you'll end up with the new map in TT Home to install at your convenience. Do backup (using Windows Explorer, copy everything to your computer hard disk), then delete the existing map and install the new one. If you don't like it, put the other one back on instead. Note - you'll "lose" your map settings, which are stored in the mapsettings.cfg file in the map folder, to recover it, you copy from your backup on your HD - take note of the mapsettings.cfg filename in the new downloaded map folder and make your replacement copy (from the old map) have the same name - at the very least, look for uppercase letters. It won't be necessary to rename the old map - even if it has the same name, it'll reside separately on the device and the only problem will be deciding which one you're using.
On my GO710, I had Western Europe with a 2Gb SD card which wouldn't accept the new map until I deleted the old one. However, after installing the new one, I found I then had enough space to put the old one back. So I can now switch between the two. _________________ Dennis
Two of them are obesiting!! |
Posted: Wed May 02, 2007 11:55 pm Post subject: |
Here's how to Change The On-screen Name Of A Map so (if you can fit them both on your sd card/harddrive) you won't have the confusion as to which is which. |
Posted: Thu May 03, 2007 7:15 am Post subject: |
Thanks chaps, appreciate your help. |
Posted: Thu May 03, 2007 7:48 am Post subject: |
Thanks to all - very helpful advice! |
