golmert Occasional Visitor
Posted: Sun Mar 07, 2004 10:06 pm Post subject: The right link |
If you cannot open the above link try doing search at Handango for rthe following:BtRegTweak |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Sun Mar 07, 2004 10:17 pm Post subject: |
Or use this link http://www.handango.com/PlatformProductDetail.jsp?productId=96903
Be aware that this mod works only on PPC2203 PC's that use the Widcomm BT Stack. There are also implications if you have multiple applications that may require access to BT services. _________________ Darren Griffin
Posted: Sun Mar 07, 2004 10:21 pm Post subject: |
Which implications?
i am using it both with a BT activesync and the BT GPS and it seems to work fine.. |
Posted: Sun Mar 07, 2004 10:27 pm Post subject: |
Read the earlier thread which discussed this Tweak here. _________________ Darren Griffin |
Posted: Sun Mar 07, 2004 10:47 pm Post subject: |
Just tried it once again-
with BT GPS there is autodetection and thats great.
With my laptop- I connect to my laptop through the BT manager as I used to do and that seems to work just fine. |
Posted: Sun Mar 07, 2004 10:51 pm Post subject: |
I'm not suggesting it won't work for you, just that in some circumstances bypassing the Bluetooth Explorer will or may cause issues ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Darren Griffin |
Posted: Sun Mar 07, 2004 10:52 pm Post subject: |
It seems that after installing the software it creates number of BT tweeks accordiing to the existing BT cconnections you configured on your BT Manager. In that case, in order to avoid a mismatch of detecting devices all you have to do is configure only one of the tweeks to autodetect and the rest will be connected manually through the BT Manager. |
