Pocket GPS World :: View topic - IPAQ H1940 and different maps istalled in sd card.
joejoe123
PostPosted: Sat Mar 06, 2004 7:55 pm    Post subject: IPAQ H1940 and different maps istalled in sd card. Reply with quote
Hi all
I have the H1940(US) with sd card(512MB) and tomtom navigator 2 with the latest software and updates.
i have 2 maps installed one is for Austria (where i live) and one for italy ,
when i try to look for something on the Austria map , all is fine and working perfect but when i try to switch maps to italy , the screen comes and disappears immediately and the navigator exits without any error message and i still can see the bluetooth GPS sign on lower right of the screen , why the navigator does not change to italy map and exits?
thanks
josef
PostPosted: Sat Mar 06, 2004 8:02 pm    Post subject: Reply with quote
That sounds like the Italy map data is corrupted. Can you re-install the Italy mapset and see if the problem is resolved?
joejoe123
PostPosted: Sat Mar 06, 2004 8:30 pm    Post subject: Reply with quote
Thanks Darren
i installed this map 3 or 4 times and still does not work , i will try to install another country and see if it works and will post it again.
thanks
josef
PostPosted: Sat Mar 06, 2004 8:33 pm    Post subject: Reply with quote
What make is the SD Card?
hbanzon
PostPosted: Sat Mar 06, 2004 10:11 pm    Post subject: Reply with quote
Quite a few people have been having this problem lately, myself included. The only way I fixed it was to ditch the two Sandisk SD cards and replace with another manufacturer (Panasonic). Works fine now!
joejoe123
PostPosted: Sun Mar 07, 2004 9:26 am    Post subject: Reply with quote
it is a Sandisk Made in china , i read that there 128 and 256 MB cause problems and i guess the 512 mb as well.
i will try a new one monday
joejoe123
PostPosted: Sun Mar 07, 2004 10:01 am    Post subject: Reply with quote
OK here are my latest Results I installed few more maps and in some it exits and in some it starts and when i try to look for something , it just freezes and will not move anymore, so i have to reset.
any final soloution? or is it the SD card?
josef
PostPosted: Sun Mar 07, 2004 10:16 am    Post subject: Reply with quote
It's almost certainly the SD Card. You could run SoftWinters's Storage Tools utility on the SD card (available in our download area), and defragment the card. Ideally though I would format it and thn re-install the maps.
This may reduce your problems but they won't go away, only solution is a different make of SD card, avoid Sandisk at all costs Thumbs Up
joejoe123
PostPosted: Sun Mar 07, 2004 1:20 pm    Post subject: Reply with quote
THanks Darren , I will just buy a new card , what is the best card available? (i will not hold u responsible if i have any problems with the new card that you suggest , I promise Smile
regards
josef
PostPosted: Sun Mar 07, 2004 1:49 pm    Post subject: Reply with quote
As long is is is not Sandisk and does not have 'Made in China' on it's reverse you should be OK with most others.
joejoe123
PostPosted: Mon Mar 08, 2004 1:27 pm    Post subject: Reply with quote
Thank you Darren and hbanzon
I bought the AVL(toshiba) 512 mb and made in japan and all is working perfect.
Thanks again
josef
22.094 (25 Sep 24)
