Pocket GPS World :: View topic - Medion 210 Poi warner gopal edition
Fatslag
Banned
PostPosted: Sun Apr 29, 2007 1:10 pm    Post subject: Medion 210 Poi warner gopal edition Reply with quote
Medion 210 Poi warner gopal edition will give you verbal sound alerts on your medion sat nav. The version of poi warner that comes with the unit is very basic and to be quite honest it is rubish so if you want sound warnings like you get in tom tom i recommend you install this works a treat! They do charge for this software but i got mine of the net for free from a french forum. info on the program ONLY can be found here http://www.navigating.de/cms/index.php?id=839
under gopal 2. I find that with this running it is as good as tomtom with picture of the cams and you can set the distance of the warnings
Fatslag
Banned
PostPosted: Mon May 07, 2007 2:59 pm    Post subject: Re: Medion 210 Poi warner gopal edition Reply with quote
To use this you must have access to your medion desktop when you have set all the options for poi warner, just run the program it will start up the navagation software
Fatslag
Banned
PostPosted: Mon May 07, 2007 3:45 pm    Post subject: setting poi warner up for the 210 Reply with quote
Im assuming you have access to the gopal desktop and you have installed poi warner, if so connect you satnav to your pc with activesync
start poi warner you will notice three red x's these need to be green when all is set properly. First click on the sync tab then click on selection tab it will connect to poi handler.com, then choose your source ie speedcams ect just scroll down the list, it is long you need UK speedcams or others what ever you chose. Then choose to sync them you will get a green tick at the bottom of right of the screen. Go back to the main menu choose paramreters choose poi pocket gatso you will notice several tabs these are for setting the warnings first tab i set as 10 seconds for both. Next tab i choose a sound file for the warnings the rest i left as default. next is the same tab but parameters the parameters, again set your options ,now all three red x's should now be green ticks and your ready to go, after the test run you know the basics so change them as you want
