joejoe123 Occasional Visitor
Joined: Mar 06, 2004 Posts: 39 Location: Vienna , Austria
Posted: Sat Mar 06, 2004 7:55 pm Post subject: IPAQ H1940 and different maps istalled in sd card. |
Hi all
I have the H1940(US) with sd card(512MB) and tomtom navigator 2 with the latest software and updates.
i have 2 maps installed one is for Austria (where i live) and one for italy ,
when i try to look for something on the Austria map , all is fine and working perfect but when i try to switch maps to italy , the screen comes and disappears immediately and the navigator exits without any error message and i still can see the bluetooth GPS sign on lower right of the screen , why the navigator does not change to italy map and exits?
thanks
josef |
Darren Frequent Visitor
![](modules/Forums/images/avatars/gallery/dg-caricature-73x73.png)
Posted: Sat Mar 06, 2004 8:02 pm Post subject: |
That sounds like the Italy map data is corrupted. Can you re-install the Italy mapset and see if the problem is resolved? _________________ Darren Griffin |
Posted: Sat Mar 06, 2004 8:30 pm Post subject: |
Thanks Darren
i installed this map 3 or 4 times and still does not work , i will try to install another country and see if it works and will post it again.
thanks
josef |
Posted: Sat Mar 06, 2004 8:33 pm Post subject: |
What make is the SD Card? _________________ Darren Griffin |
hbanzon Occasional Visitor
Posted: Sat Mar 06, 2004 10:11 pm Post subject: |
Quite a few people have been having this problem lately, myself included. The only way I fixed it was to ditch the two Sandisk SD cards and replace with another manufacturer (Panasonic). Works fine now! |
Posted: Sun Mar 07, 2004 9:26 am Post subject: |
it is a Sandisk Made in china , i read that there 128 and 256 MB cause problems and i guess the 512 mb as well.
i will try a new one monday |
Posted: Sun Mar 07, 2004 10:01 am Post subject: |
OK here are my latest Results I installed few more maps and in some it exits and in some it starts and when i try to look for something , it just freezes and will not move anymore, so i have to reset.
any final soloution? or is it the SD card?
josef |
Posted: Sun Mar 07, 2004 10:16 am Post subject: |
It's almost certainly the SD Card. You could run SoftWinters's Storage Tools utility on the SD card (available in our download area), and defragment the card. Ideally though I would format it and thn re-install the maps.
This may reduce your problems but they won't go away, only solution is a different make of SD card, avoid Sandisk at all costs ![Thumbs Up](modules/Forums/images/smiles/custom2.gif) _________________ Darren Griffin |
Posted: Sun Mar 07, 2004 1:20 pm Post subject: |
THanks Darren , I will just buy a new card , what is the best card available? (i will not hold u responsible if i have any problems with the new card that you suggest , I promise
regards
josef |
Posted: Sun Mar 07, 2004 1:49 pm Post subject: |
As long is is is not Sandisk and does not have 'Made in China' on it's reverse you should be OK with most others. _________________ Darren Griffin |
Posted: Mon Mar 08, 2004 1:27 pm Post subject: |
Thank you Darren and hbanzon
I bought the AVL(toshiba) 512 mb and made in japan and all is working perfect.
Thanks again
josef |
