Pocket GPS World :: View topic - Speed Cam readout on Mio3.2
PostPosted: Fri Apr 27, 2007 9:20 am    Post subject: Speed Cam readout on Mio3.2 Reply with quote
I have solved the problem of the speed camera limit and average speed (in SPECS zones) being in Km/H not MPH. The fix involves editing the patch.ui file in data.zip so is not for a newbee. If anyone is interested in my solution, I will post the mods to patch.ui here.
Trevor
Teece
PostPosted: Fri Apr 27, 2007 12:40 pm    Post subject: Re: Speed Cam readout on Mio3.2 Reply with quote
Trevor
Yes please Trevor, this is a fundamental problem with miomap which they seem very reluctant to fix.
PostPosted: Fri Apr 27, 2007 3:03 pm    Post subject: Reply with quote
Tece
Instructions to follow.
I have contacted Mio several times. I am certain that they do not understand the problem. I sent them quite a detailed email, and they told me how to change the basic units from metric to Imperial. Like I didn't already know. My second brought the response, download the latest. It aint fixed in that either, but I did loose my TMC so back to the Sept 06 version and my mods.
PostPosted: Fri Apr 27, 2007 3:29 pm    Post subject: Reply with quote
Herewith my fix for the MPH speed camera readout.
I have intercepted the value of speedlimit (vspeedlimit) if the Mio is in Imperial, and converted the value from km/h to MPH in a lookup table before display. The anomaly of the speed limit already being in MPH within a SPECS zone sorts itself out OK because the speed passed to the lookup will be 30, 40 etc. which are not in the conversion table so will not be converted. Similarly I have done the same thing for the average speed (vAvgSpeed) for the SPECS zone. All readouts are in MPH. If your Mio is set to Km/m then no conversion is done, as the speed readout should be OK. :D
You need to make the changes, shown below in bold to the data.zip\ui_mio\Patch.ui file (except the first two remmed out lines of script sc_show_speedlimit). Replace the ~ with open or close triangular brackets as required.
~script sc_show_speedlimit~
;The runifnot statement runs the conversion if Mio is set to Miles
;bUnitType : Kilometers/meters=1 Miles/yards=0 Miles/feet=2
txt_limit_text.show
txt_speed_limit.show
spr_speedwarn_bg.show
runifnot bUnitType 1 'run sc_Convert_To_MPH vspeedlimit'
txt_speed_limit.text vspeedlimit
~/script~
~script sc_Convert_To_MPH~
runif $1 48 'vspeedlimit.set 30'
else_runif $1 64 'vspeedlimit.set 40'
else_runif $1 80 'vspeedlimit.set 50'
else_runif $1 96 'vspeedlimit.set 60'
else_runif $1 112 'vspeedlimit.set 70'
~/script~
~script sc_show_avgspeed~
txt_dist_avgpseed_text.text "Av Spd:"
runifnot bUnitType 1 'run sc_Convert_Av_To_MPH vAvgSpeed'
txt_dist_avgpseed.text vAvgSpeed
~/script~
~script sc_Convert_Av_To_MPH~
runif $1 10 'vAvgSpeed.set 6'
else_runif $1 11 'vAvgSpeed.set 7'
else_runif $1 12 'vAvgSpeed.set 8'
else_runif $1 13 'vAvgSpeed.set 8'
else_runif $1 14 'vAvgSpeed.set 9'
else_runif $1 15 'vAvgSpeed.set 9'
else_runif $1 16 'vAvgSpeed.set 10'
else_runif $1 17 'vAvgSpeed.set 11'
else_runif $1 18 'vAvgSpeed.set 11'
else_runif $1 19 'vAvgSpeed.set 12'
else_runif $1 20 'vAvgSpeed.set 13'
else_runif $1 21 'vAvgSpeed.set 13'
else_runif $1 22 'vAvgSpeed.set 14'
else_runif $1 23 'vAvgSpeed.set 14'
else_runif $1 24 'vAvgSpeed.set 15'
else_runif $1 25 'vAvgSpeed.set 16'
else_runif $1 26 'vAvgSpeed.set 16'
else_runif $1 27 'vAvgSpeed.set 17'
else_runif $1 28 'vAvgSpeed.set 18'
else_runif $1 29 'vAvgSpeed.set 18'
else_runif $1 30 'vAvgSpeed.set 19'
else_runif $1 31 'vAvgSpeed.set 19'
else_runif $1 32 'vAvgSpeed.set 20'
else_runif $1 33 'vAvgSpeed.set 21'
else_runif $1 34 'vAvgSpeed.set 21'
else_runif $1 35 'vAvgSpeed.set 22'
else_runif $1 36 'vAvgSpeed.set 23'
else_runif $1 37 'vAvgSpeed.set 23'
else_runif $1 38 'vAvgSpeed.set 24'
else_runif $1 39 'vAvgSpeed.set 24'
else_runif $1 40 'vAvgSpeed.set 25'
else_runif $1 41 'vAvgSpeed.set 26'
else_runif $1 42 'vAvgSpeed.set 26'
else_runif $1 43 'vAvgSpeed.set 27'
else_runif $1 44 'vAvgSpeed.set 28'
else_runif $1 45 'vAvgSpeed.set 28'
else_runif $1 46 'vAvgSpeed.set 29'
else_runif $1 47 'vAvgSpeed.set 29'
else_runif $1 48 'vAvgSpeed.set 30'
else_runif $1 49 'vAvgSpeed.set 31'
else_runif $1 50 'vAvgSpeed.set 31'
else_runif $1 51 'vAvgSpeed.set 32'
else_runif $1 52 'vAvgSpeed.set 33'
else_runif $1 53 'vAvgSpeed.set 33'
else_runif $1 54 'vAvgSpeed.set 34'
else_runif $1 55 'vAvgSpeed.set 34'
else_runif $1 56 'vAvgSpeed.set 35'
else_runif $1 57 'vAvgSpeed.set 36'
else_runif $1 58 'vAvgSpeed.set 36'
else_runif $1 59 'vAvgSpeed.set 37'
else_runif $1 60 'vAvgSpeed.set 38'
else_runif $1 61 'vAvgSpeed.set 38'
else_runif $1 62 'vAvgSpeed.set 39'
else_runif $1 63 'vAvgSpeed.set 39'
else_runif $1 64 'vAvgSpeed.set 40'
else_runif $1 65 'vAvgSpeed.set 41'
else_runif $1 66 'vAvgSpeed.set 41'
else_runif $1 67 'vAvgSpeed.set 42'
else_runif $1 68 'vAvgSpeed.set 43'
else_runif $1 69 'vAvgSpeed.set 43'
else_runif $1 70 'vAvgSpeed.set 44'
else_runif $1 71 'vAvgSpeed.set 44'
else_runif $1 72 'vAvgSpeed.set 45'
else_runif $1 73 'vAvgSpeed.set 46'
else_runif $1 74 'vAvgSpeed.set 46'
else_runif $1 75 'vAvgSpeed.set 47'
else_runif $1 76 'vAvgSpeed.set 48'
else_runif $1 77 'vAvgSpeed.set 48'
else_runif $1 78 'vAvgSpeed.set 49'
else_runif $1 79 'vAvgSpeed.set 49'
else_runif $1 80 'vAvgSpeed.set 50'
else_runif $1 81 'vAvgSpeed.set 51'
else_runif $1 82 'vAvgSpeed.set 51'
else_runif $1 83 'vAvgSpeed.set 52'
else_runif $1 84 'vAvgSpeed.set 53'
else_runif $1 85 'vAvgSpeed.set 53'
~/script~
You may also change the size of the text on the graphic so that you can more easily read it now that the readings are more relevant. 8O
Again in patch.ui change the positioning and font size of the readout as below.
~layer ui_warning_layer~
~sprite spr_speedwarn_bg x=78 y=53 bmp="speed_bg.bmp" ~
~sprite sp_camera_type x=80 y=118 bmp="speed_cams.spr" onrelease='speedwarn_end_section'~
~text txt_limit_text text="Limit:" x=80 y=48 w=50 h=20 align="LEFT" fontsize=12 fonttype=buttonlabel_menu~
~sprite spr_speedwarn_bg1 x=78 y=84 bmp="speed_bg.bmp" ~
~text txt_speed_limit x=80 y=58 w=50 h=20 align="RIGHT" fontsize=24fonttype=buttonlabel_menu font="tahomabd"~
~text txt_dist_avgpseed_text text="Distance:" x=80 y=78 w=50 h=20 align="LEFT" fontsize=12 fonttype=buttonlabel_menu ~
~text txt_dist_avgpseed x=80 y=88 w=50 h=20 align="RIGHT" fontsize=24 fonttype=buttonlabel_menu font="tahomabd"~
~/layer~
I am still working on the single alert telling you what type of camera you are approaching. It works sort of OK if the voice and cam alert volumes are set fairly high, but am having a problem with resetting the master volume back to how it was. It tends to stay at the same volume setting as I set it for the alert. Perhaps I'm trying to be a bit too clever. Wink
Teece
PostPosted: Fri Apr 27, 2007 3:48 pm    Post subject: Reply with quote
Excellent Trevor, your a star Thumbs Up
MazzaD
PostPosted: Sun Sep 16, 2007 11:10 pm    Post subject: Saving the file Reply with quote
Tece
I have updated the file as per your instructions, however cannot seem to get it to save - the folder stops responding and i have to close it down. Can you help please because seeing speeds in kph is annoying.
PostPosted: Mon Sep 17, 2007 8:34 am    Post subject: Reply with quote
MazzaD
PM Me with your email and I'll see what I can do to help.
DeeJay01
PostPosted: Mon Sep 17, 2007 10:23 am    Post subject: Re: Speed Cam readout on Mio3.2 Reply with quote
Trevor
Hi Trevor,
You have probably sent this already but can you send it again. Also does it show normal speed cams in MPH.
You should have my email address already (@bt.com)
Regards
Dave J
View user's profile Send private message Yahoo Messenger
