Pocket GPS World :: View topic - Camera location and direction
AlfaIan
PostPosted: Thu Apr 26, 2007 1:01 pm    Post subject: Camera location and direction Reply with quote
Sorry if this is in the wrong section.
I'm finding that the speed camera locations are alerting me of camera's on the wrong side of the road which are for traffic going in the other direction. Or even parrall roads.
Is there a way of stopping this?
Device is a tomtom6 on PDA.
Privateer
PostPosted: Thu Apr 26, 2007 2:37 pm    Post subject: Reply with quote
Hi AlfaIan,
The only was to stop alerts on the other side of the road is to set your TomTom Proximity Alerts and check the "Warn only if POI is on route" box.
NB. If you check the "Warn only if POI is on route" box, then you will not be warned of POIs that you approach if:
1. The POIs are slightly away from the road.
2. You have no destination and therefore no route planned.
You may still be warned of cameras for the opposite direction, when you are on single carriageway roads.
Robert.
Garmin Camper 770 LMT-D
AlfaIan
PostPosted: Thu Apr 26, 2007 3:19 pm    Post subject: Reply with quote
So until there is a fix I’ll have to get use to it.
Thanks for the answer
desd
PostPosted: Thu Apr 26, 2007 6:42 pm    Post subject: Reply with quote
I've been having the same problem with my zumo??
I thought it did directional but maybe im wrong
Zumo 500 + 4GB SD Card, car Kit and GTM21
Linked to Autocom by bluetooth and all seems good.
Traffic reception in the central belt of Scotland and hurray NW England seems to be working again. Still a million times better than the Quest 2 it replaces
PostPosted: Thu Apr 26, 2007 10:15 pm    Post subject: Reply with quote
as far as i am aware, the only units that can use directional data are drivesmart and some of the newer mio units.
also, these are teh only PGPSW downloads that include the heading data.
PostPosted: Fri Apr 27, 2007 12:22 pm    Post subject: Reply with quote
Adding to Privateer's reply:
You WILL get alerts from cameras on the other side of the road (rather than "might").
This is because as far as the TomTom is concerned the whole road is a single route.
The only time you won't (although it still happens ocasionally) is on dual carriageways, which are seen as two seperate routes (look at the colour of the road when you have a route planned).
The other time it happens on dual carriageways (which I find really annoying) is when a camera position - often a mobile site - is positioned on the roundabout off a slip road. These throw up spurious "30" warnings for example, as you are bombing down the motorway. This seems to be a function of the maps (or the way the softwarte interprets them, as it has definitely got worse as I have updated).
It seems as if the whole junction has been included with the main road as part of "the route".
I think you just have to get used to it, until the technology is more sophisticated.
desd
PostPosted: Sat Apr 28, 2007 8:25 am    Post subject: Reply with quote
Im getting alerts on the A90 to Aberdeen for both directions and as dual carriage ways go they dont get much wider
PostPosted: Mon Apr 30, 2007 9:47 am    Post subject: Reply with quote
As I said in my last post:
Unfortunately, we are never likely to be let into the secrets of how the software interacts with the maps, as all the manufacturers will see that as a vital commercial secret.
It also affects how some navigation instructions are a bit wierd - when does a straight road, become a bend, then become a turn, for example.
22.094 (25 Sep 24)
