Pocket GPS World :: View topic - Guide To Creating A POI (Point Of Interest)
Goto page Previous  1, 2, 3, 4, 5  Next
cabsandy666
PostPosted: Thu Jun 15, 2006 3:21 pm    Post subject: Reply with quote
Steve,
Is there any way your piece of work could be adapted to include a box where you could input a post code directly and the Google map will zoom automatically to it?
Sandy
wherethehellarewe
PostPosted: Thu Jun 22, 2006 10:45 am    Post subject: Reply with quote
Hi All,
A newbie here trying to create his first POI for the Garmin i3. I seem to have a problem saving my file in note pad, it only gives me the option to save it as a .txt file, is this correct ? I thought I'd have to save it as a .asc file. Sad
Ignorance is no excuse !
PostPosted: Thu Jun 22, 2006 11:06 am    Post subject: Reply with quote
Just use Windows Explorer to re-name the file extension, right click your saved file select re-name, call the file wahtever you like .asc, make sure that in Windows Explorer you have Tools/ Folder Options - View Tab "Hide extensions for known file types" de-selected - Mike
NedKelly
PostPosted: Mon Sep 11, 2006 4:55 pm    Post subject: Reply with quote
I wanted to make a POI of roadside cabs that i visit at work.
When i arrived at each cab i noted down the GPS co-ordinates and they are in the format
51 12' 5.6"N, 2 14' 23.5"W (can't find degree symbol on keyboard)
how do i convert them to decimal format as in the example given?
NedKelly
PostPosted: Mon Sep 11, 2006 5:04 pm    Post subject: Reply with quote
Found out how to do it here
http://www.MaFt.co.uk/garmin/info_convert.htm
stevedbentley
PostPosted: Thu Oct 19, 2006 10:44 pm    Post subject: Reply with quote
cabsandy666 wrote:
Steve,
Sandy
Hi Sandy
I have now (eventually) managed to get hold of the data needed to do this, and approximate UK postcode lookups are now possible on autopoilot.co.uk
Steve Smile
mark2004uk
PostPosted: Wed Jan 03, 2007 8:25 pm    Post subject: I have done all this Reply with quote
I cant do it, i have created this :
;Longitude, Latitude, Accrington Moorhead Sports College
-2.374967,53.760368 Accrington BB5 4FF
in a wordpad and a notpad file and WinOV2 wont open it !
is everythin correct on the file ?? why wont it open ??
Tim Buxton
PostPosted: Wed Jan 03, 2007 8:50 pm    Post subject: Reply with quote
Never used Winov2 but do you need a comma after your lat coordinate?
Tim
mark2004uk
PostPosted: Thu Jan 04, 2007 9:05 pm    Post subject: mmmmmm Reply with quote
Nothin its not happenin' the file will not open with the programme !
PostPosted: Thu Jan 04, 2007 9:27 pm    Post subject: Reply with quote
Which version of WinOV2 are you using?
V2 will open ASC and CSV Files Text Files only. V1 can only open an ASC Text File.
TT Via 135 App 12.075: Europe Map v1140
tubzy1
PostPosted: Tue Apr 17, 2007 3:22 pm    Post subject: Thank you Reply with quote
I am new to this sat nav thing and just wanted to say a big thanks for this guide (youre probably bored of receiving alll these thanks but there it goes).
Any ideas how to create a CATEGORY for a poi on your database. I submitted a poi but couldnt find a CATEGORY that matches EXACTLY what I wanted to add
aj2052
PostPosted: Tue Apr 17, 2007 4:06 pm    Post subject: Reply with quote
Tubzy1 asked
Use add new poi,In Category select other poi, and suggest new category in comments or details.
tubzy1
PostPosted: Tue Apr 17, 2007 4:18 pm    Post subject: Thank You Reply with quote
Thank you very much
cherio
PostPosted: Thu Apr 19, 2007 11:36 pm    Post subject: Utility: finds and iliminates/marks duplicate POIs Reply with quote
After reading POIs related forums I have wrote a utility for processing CSV files. Since I am not planning to sell it I decided to let others benefit from it as well.
This utility can:
* Find and mark duplicate POIs
* Eliminates duplicate POIs
* Handle POI file lists. It can as well merge files or process them individually
* Set the distance within which POIs will be considered as duplicates.
* The result is always saved into CSV file.
This can be really useful for editing and processing POI lists.
Just today I registered a project on sourceforge.net (POI Duplicate Finder-Remover). As soon as they approve the project I will upload the source code and the executable. Meanwhile if anyone wants/needs this utility - let me know.
cherio
PostPosted: Mon Apr 23, 2007 4:03 pm    Post subject: Re: Utility: finds and iliminates/marks duplicate POIs Reply with quote
The utility described below can not be found here:
https://sourceforge.net/projects/poi-dup-finder/
Right now I am working on the command line version of this program.
This utility can:
Page 3 of 5
22.123 (18 Dec 24)
