Pocket GPS World :: View topic - vanishing cameras
vanishing cameras
billaricky
PostPosted: Sat Apr 21, 2007 7:20 am    Post subject: vanishing cameras Reply with quote
hello all, my problem: tom tom go510 ver 6.524
before i updated to latest firmware all of my speed cams showed up in the poi's 30,40,50 etc, now all i can see are my temp-red light cams, when i put the sd card into the pc the safety cams show up as being on the card but when i put the card back into the tom-nothing, i have looked everywhere, i only have 4 poi's selected, any help gratefully received...... ps the cams are located in the maps folder, each cam has a bmp and a ov2 file
Daggers
PostPosted: Sat Apr 21, 2007 1:31 pm    Post subject: Reply with quote
How many POI files have you got installed on the TT? Could it be more than 100? (Note: not the number SELECTED, but the number of .OV2 files actually on the SD card).
if it is more than 100, you'll probably have to try deleting a few.
billaricky
PostPosted: Sun Apr 22, 2007 9:53 am    Post subject: Reply with quote
thanks for the reply, i have only got about 50 poi's and like i said i only have 4 of those checked, when i viewed a demo of a route the cameras did show up, but when i look for them in my poi's to set a warning tone/distance for example, they are'nt there, HELP!!!, thanks
andydigital44
PostPosted: Sun Apr 22, 2007 10:34 am    Post subject: Reply with quote
It doesn't matter how many poi's you have got checked. If for example you have 110 poi's in the map folder and only 1 checked in the show list you will still only be able to see 100 of those poi's in the list where you can put a check mark next to it, the other 10 poi's will be invisible until you reduce the total amount of poi files to 100 or less.
The above doesn't include tomtom supplied POI's they are stored elsewhere and don't count.
PostPosted: Mon Apr 23, 2007 12:25 am    Post subject: Reply with quote
The full set of PGPSW speed cams now takes up 33 categories (although 2 are always empty and another 7 are unverified "possibles", so you only need to have 68 other categories to start getting into trouble.
Just count the number of ov2 files in your map folder using Windows Explorer, and tell us how many you find.
22.063 (19 Jun 24)
