Pocket GPS World :: View topic - Problem transfering copilot to a bigger sd card
Encio
PostPosted: Tue Mar 13, 2007 8:14 pm    Post subject: Problem transfering copilot to a bigger sd card Reply with quote
Can anyone help me PLEASE!!!! i bought a copilot software preinstalled in a 256mb microsd and i want to transfer the software to a bigger sd card because 256 is just too small. the problem is after i have installed it and run it it says "unable to open copilot, please make sure the compact flash card is inserted or that the data has been properly downloaded" i did check and even reinstall and as far as i know everything is ok aside from the software not running. but when i use the software with the original sd card it does work. i never had problem using different memory card with TomTom 6 but with co pilot its a whole different story.
So if someone has the same problem and fixed it can you please let me know. thanks!!!!
Border_Collie
PostPosted: Wed Mar 14, 2007 1:09 am    Post subject: Reply with quote
Hidden files usually cause this problem.
Try again by starting My Computer - Tools - Folder Options - View and click on Show hidden files and folders.
Bingo_Accent
PostPosted: Fri Mar 30, 2007 1:45 pm    Post subject: Reply with quote
Make sure you didn’t do what I did…
I created a folder on my memory card called ‘Co Pilot’ and saved the two sub-folders (‘2577’ and ‘COPILOT’) there – the idea being to at least start off with a tidy filing structure….
I got the same message you’re getting, and had to move the two folders ‘up’ to the top level in order that the .exe file could run.
fluffball
PostPosted: Fri Apr 20, 2007 1:16 pm    Post subject: Reply with quote
The first thing I did when I got the s/w was take copy of the 256KB card (using PC and card reader with show hidden files turned on) before I even plugged it in. Later I deativated CoPilot, copied the image to a 4GB card duplicated the structure exactly. Forced the install to re-run and re-activated it. No problems so it can be done.
kaapstad82
PostPosted: Tue Jun 05, 2007 9:59 pm    Post subject: transfare copilot to bigger memory card Reply with quote
1-deactivate existing copilot
2-open new file/folder on your pc and name "copilot 2".
3-insert original copilot memory card into card read on pc
4-copy copilot memory card files onto "copilot 2"
5-insert bigger memory card into reader
6-copy "copilot 2" onto bigger memory card
7-download the file from alk below. http://www.alk.eu.com/files/S60-3rd/copilot_s60_21_6.0.8.110.zip
8-copy the above onto your bigger memory card.
9-insert and load/overwrite onto phone
10-register with alk & use
Kram
PostPosted: Tue Nov 13, 2007 2:44 pm    Post subject: Re: transfare copilot to bigger memory card Reply with quote
Thank-you for those detailed notes on how to move to a larger memory card. I used them to install to the memory-card-less N95 8GB and it *almost* works.
I now have it installed and can use the software ok, but only as the 3 day evaluation. When I try to register/activate it gets part-way through that process, I enter the long code supplied with the software, I receive an email with the registration code, but the N95 locks up and doesn't give me chance to enter the code.
I have a call in to the support line about this but I thought I'd mention it here in case anyone else has already seen and solved the problem.
Thanks,
Mark.
crash
PostPosted: Mon Feb 11, 2008 3:42 pm    Post subject: Reply with quote
can you use this process to back up your software. i've considered buying copilot live but didn't like idea of being stuck with a 2gb card and not a dvd or cd set. thanks in advance.
MGTF
PostPosted: Wed Feb 13, 2008 1:48 pm    Post subject: Reply with quote
i copied the orginal 1Gb card that came with Copilot 7 to my hard disk and then copied those files to a 2Gb card. it all installed and worked OK.
i have now just copied the current 2Gb card to my hard disk and copied all those files back to a 4GB SDHC card for My Orbit.
I did not have to deactivate copilot all worked Ok..
I used a card reader for all the copying.....
stone95
PostPosted: Tue Feb 19, 2008 5:18 am    Post subject: Reply with quote
Well, in fact, you could recreate your storage card as mentioned in their support site:
Recreate Storage Card
Smile
muckypup
PostPosted: Thu Mar 20, 2008 11:14 pm    Post subject: Reply with quote
Here is a nice PDF with pictures that shows the procedure.
http://www.alk.eu.com/files/manuals/V7ppc-DDW.pdf
I was considering the new Garmin software but the copilot software looks better and you can officially install the maps on any card you want!
S.
Montala
PostPosted: Thu Mar 27, 2008 12:38 pm    Post subject: Reply with quote
...that is of course assuming that you are able to install CoPilot Central from the DVD supplied, and subsequently update the necessary files... which I am not currently able to do, due to a known bug which ALK are currently trying to fix.
Not good!
