billconant Occasional Visitor
Joined: Jul 19, 2006 Posts: 27 Location: Quincy, Massachusetts USA
Posted: Thu Apr 19, 2007 2:43 pm Post subject: How do you find the address of created POI? |
Hello All,
I've created a POI category for my work locations using the address of the sites I travel to. I can't find anyway to display that address once the POI is created. I didn't include the address in the name field when I created them figuring I could use the edit function if I wanted to see the actual address. But the address doesn't show up when you edit. I've found that I have to plan a route then browse the map and tap on the POI or close to it to display the address. I need to give my coworkers these addresses from time to time and find it a nuisance to find the address by browsing a map. Maybe I'm missing something that you all can tell me about.
Bill |
Posted: Thu Apr 19, 2007 4:39 pm Post subject: |
You could download and install POIEdit and use that to open your creation (the ov2 file) and then edit the name to whatever you need - I hope you still have the list of addresses and Lat/ Longs though otherwise this could take you some time if its a long list - Mike |
Posted: Fri Apr 20, 2007 12:31 pm Post subject: |
Thanks Mike for replying. The thing is I don't want the address in the name of the POI as it would be difficult to chose from the list of POI. And I can change the name of the POI using the edit POI function without using an external program. I'm trying to find away to see the underling address that was used to create the POI in the first place without having to create a route and browsing the map to get it.
Bill |
Adamwest Occasional Visitor
Posted: Sun Apr 22, 2007 6:41 am Post subject: |
I want what Bill wants but don't think it can be done on TT6 |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10644 Location: Suffolk, UK
Posted: Sun Apr 22, 2007 7:37 am Post subject: |
It's not a facility that TT6 has. If you need the address in the POI name, (this is searchable if need be, for navigation purposes) you don't need to create a route.
Unfortunately it's a 2 step process.
1. In Browse Map, use Find to locate all the sites, and write down the Current Name and the associated Text.
2. Then Edit the POI category, either using the built in Edit Function or POIEdit, and append the address details. Personally, external editing is much quicker.
Not an ideal solution, but there is little choice.  _________________ Richard
TT Via 135 App 12.075: Europe Map v1150 |
