Pocket GPS World :: View topic - NO GPS DEVICE! PLEASE HELP
eddiedzung
PostPosted: Wed Apr 11, 2007 1:45 pm    Post subject: NO GPS DEVICE! PLEASE HELP Reply with quote
Hi there, i had a hp ipaq rx 5765 pda, my gps used to work fine, after i lended it to my friend ,when i got it back, i can not use gps again. when i open TOM TOM then it showed NO GPS DEVICE! does anyone know to reset the GPS ? thank you in advance.
EDDIE
Ratspom
PostPosted: Wed Apr 11, 2007 9:18 pm    Post subject: Reply with quote
I think you may need to go into the programs list of your device
Tap the start then programs and then GPS, make sure there is a tick in the COM Port selection box for the Correct GPS antenna you are using
EG:- if using a TomTom "Mouse" (the one on the end of a lead) this one uses com port 3 ....well on my IPAQ 3950 it does.
Hope that helps
Mac
View user's profile Send private message Yahoo Messenger
Ratspom
PostPosted: Thu Apr 12, 2007 7:46 pm    Post subject: Reply with quote
OK forget my last bit of advice but follow this from Mike
When using TomTom version 5 you do not use the seperate GPS program to set-up the device, instead go to Change Preferences/ Show GPS Status then hit the configure button, it is in this area that you specify the comm port, baud rate etc.
Make sure the GPS driver for the earlier version is not running though as it could be hogging the comm port - start/ settings/ system Tab_Memory_Running Programs and if its listed stop it before launching navigator five - Mike
Worked for me
philpugh
PostPosted: Fri Apr 13, 2007 1:50 pm    Post subject: Reply with quote
If it's a serial GPS also check that ActiveSync isn't running in background.
Kill ALL running apps and try again using the info in the post above from Ratspom
Phil
eddiedzung
PostPosted: Sat Apr 14, 2007 5:42 am    Post subject: Reply with quote
Worked for me
i tried that but it still not working? Sad Do i have to set the hardware and Baud rate? thanks Ratspom and Phil
22.064 (26 Jun 24)
