Pocket GPS World :: View topic - Saving route tomtom one v2
pppvqp
PostPosted: Tue Apr 10, 2007 10:19 am    Post subject: Saving route tomtom one v2 Reply with quote
I have configured my route to work, so it gets me there the way I want to go.
How do I save this? So when I use traffic it will check this route not the way tom tom wants to send me.
Thanks Jim
tonys66
PostPosted: Tue Apr 10, 2007 1:20 pm    Post subject: Reply with quote
What device are you using might help if we knew
pppvqp
PostPosted: Tue Apr 10, 2007 2:10 pm    Post subject: Reply with quote
I put it in the subject header.
It is TomTom one V2
Thanks Jim
JockTamsonsBairn
PostPosted: Tue Apr 10, 2007 7:01 pm    Post subject: Re: Saving route tomtom one v2 Reply with quote
Thanks Jim
Search for info on itineraries. See if that would suit.
Jock
sgould
PostPosted: Tue Apr 10, 2007 7:02 pm    Post subject: Reply with quote
Save it as an Itinerary. You don't need to enter you start point. The TT knows where you are.
TTGO 700 (dead)
iPhone 3GS + TT holder
iPhone 5 (hers!)
Western Europe Map
Eastern Europe Map
Robin2
PostPosted: Tue Apr 10, 2007 11:15 pm    Post subject: Reply with quote
And if you want to plan and save an itinerary starting from a point other than your current location, plan the itinerary in TomTom Home (having first set your current location as the point you want the itinerary to start from), then Save under Options.
I am going to France on Friday, and have saved several itineraries there using this method
Robin
Satmap Active 10
Robin2
PostPosted: Tue Apr 10, 2007 11:22 pm    Post subject: Reply with quote
Robin2 wrote:
...... in TomTom Home (having first set your current location as the point you want the itinerary to start from), then Save under Options.
Robin
To clarify my rather clumsy wording above....using TomTom Home you can simulate the current location to be anywhere you like. Set it to the desired start point of your itinerary, then use the simulated screen in TomTom Home to plan, and save, a route starting from that point. It will be saved in your device when you disconnect it from the PC, and you can load the saved itinerary when you reach the start point you used.
Robin
Satmap Active 10
RQ
PostPosted: Wed Apr 11, 2007 8:02 am    Post subject: Reply with quote
There is a programme called Tyre available Here
You can plan and save itineraries with this. It links into google map or earth (can't remember which) and works quite well.
Regards
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
RQ
PostPosted: Wed Apr 11, 2007 8:03 am    Post subject: Reply with quote
FYI
It links to Google Earth
RQ
pppvqp
PostPosted: Wed Apr 11, 2007 8:45 pm    Post subject: Reply with quote
Tried Robin2 and Rq's method both work perfectly.
Enjoyed playing google Earth as well. :D
Thanks Jim
22.094 (25 Sep 24)
