Pocket GPS World :: View topic - Help with tomtom on Lifedrive - keeping screen on
superman
PostPosted: Sun Apr 09, 2006 1:56 pm    Post subject: Help with tomtom on Lifedrive - keeping screen on Reply with quote
Hi all
Just been given a lifedrive and tomtom which all works well apart from when it is not plugged in to a charger the screen goes off after a minute.
This is fine normally as it save battery but it still goes off when running navigater 5, so i can get 1 minutes worth of navigation and then have to turn it back on.
Can anyone point me in the right direction
thanks
eillo7
PostPosted: Sun Apr 09, 2006 6:38 pm    Post subject: Reply with quote
You could try opening a new memo and writing the 'shortcut symbol' followed by .3
(the 'shortcut symbol' is like how you were taught to write a joined up lower case 'L').
This disables the auto-off feature in many older handhelds, and may still work in the LD but I don't know for sure. Try it... Wink
...oh, and by the way, a soft reset will revert settings to normal afterwards. Smile
If this doesn't work, there's a program called Handyaid that allows you to disable auto-off for selected applications (and it does alot more too).
nigelho
PostPosted: Sun Apr 08, 2007 8:48 am    Post subject: Reply with quote
I do not believe there is a way to keep the Palm on without charging the device. All palms I know, I have had 9 different models and they all auto turn off after a few minutes. You can keep them on but only whilst charging.
Beware though you need to disable the security settings (auto lock) as that overides the power off.
eillo7
PostPosted: Sun Apr 08, 2007 6:27 pm    Post subject: Reply with quote
Handyaid is a software app that enables you to prevent auto-off on specified applications. But it does cost money...
There may be freeware apps that do the same thing if you look for them.
nigelho
PostPosted: Mon Apr 09, 2007 11:03 am    Post subject: Reply with quote
Found an app called SetAutoOff written by a palm addict. It is freeware and is only 2.0k if you would like a copy send me a message and I will forward it to you
nigelho
PostPosted: Mon Apr 09, 2007 11:07 am    Post subject: Reply with quote
This may also work, freeware as well
www.palmgear.com/index.cfm?fuseaction=software.showsoftware&prodid=62989
22.063 (19 Jun 24)
