Pocket GPS World :: View topic - GPSlim236 troubles
GPSlim236 troubles
Goto page Previous  1, 2
jpc1284
PostPosted: Sat Mar 31, 2007 4:10 am    Post subject: Reply with quote
Hey can i do a cold start via bluetooth or will that brick my unit. also i saw a factory reset mode on the sirf can that be done via bluetooth as well or not.
Skippy
PostPosted: Mon Apr 02, 2007 12:16 am    Post subject: Reply with quote
You can cold start it without causing any problems. It will take the standard 45 seconds or so to get a lock, that's all.
If you factory reset it then it might take a couple of minutes to get a lock - make sure you have a good sky view and some patience if you do this!
Gone fishing!
jpc1284
PostPosted: Mon Apr 02, 2007 1:11 am    Post subject: Reply with quote
SO you can do the factory reset via bluetooth though correct? Also just an update for those how have been helping me. One thing i noticed is that i have yet to have it not work after letting it sit over night.(with the batter still in) So far i have been able to turn it on and fix today with no problem 3 times. So as for now it seems just as along as i don't turn it on and off in short periods of time its works. plus i figure that if i am making trips where i would be turning it on and off ill just leave it on and connect the car charger so it doesn't go dead.
russy121
PostPosted: Sat Apr 07, 2007 8:58 pm    Post subject: Reply with quote
when i connect my slim236 to my pc via usb
my usb freaks out saying that
one of the USB devices attached to this computer has
malfunctioned, and windows does not recognize it.
any one any idea
i have install the drivers all fine (i think)
i will say i did purchase it off of ebay
PostPosted: Sat Apr 07, 2007 10:28 pm    Post subject: Reply with quote
Nowt to worry about. Unless you use the specific USB to GPSlim cable it will not work as a Serial GPS and so Windows throws a wobbly and gives that error. It will however charge from USB using any normal USB Mini to USB cable.
Page 2 of 2
22.063 (19 Jun 24)
