thebinman Banned
![](http://www.pocketgpsworld.com/images/banned_user.jpg)
Posted: Fri Apr 06, 2007 5:06 pm Post subject: Rider can't bluetooth pair with WE v660? |
Installed a WE v660 SD in a Rider and works fine BUT although the unit finds/pairs with the bluetooth headset with the orig GB card in, this WE card just won't do it.
Noticed on the Rider GB v612 there's a1.59Kb file called ppp.
Should this be added to the v660 WE card or is there another trick? |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Fri Apr 06, 2007 8:18 pm Post subject: |
With the testing I do, I swap SD cards quite regularly and have never had a problem pairing with the TomTom BT device or my WellTech kit that I use in the car. _________________ Tim |
thebinman Banned
Posted: Sat Apr 07, 2007 11:11 am Post subject: |
Tim Buxton wrote: | With the testing I do, I swap SD cards quite regularly and have never had a problem pairing with the TomTom BT device or my WellTech kit that I use in the car. |
thanks Tim.
Can you or someone else just check to see if the 1.59Kb "ppp" file which is on an original Rider GB card is present on any other SD card that works correctly in a Rider.
Thanks |
Posted: Sat Apr 07, 2007 8:16 pm Post subject: |
thebinman wrote: |
thanks Tim.
Thanks |
I have a directory called PPP on the SD card. I think it has something to do with the GPRS connection, judging by its contents. _________________ Tim |
thebinman Banned
Posted: Sun Apr 08, 2007 10:20 am Post subject: |
OK, thanks Tim |
