cosworth4x4 Occasional Visitor
Posted: Wed Mar 21, 2007 11:50 pm Post subject: tomtom 510 reset. |
is there a way i can reset it back to the day i bought it,basically ive loaded speed cameras and voices witch i dont thenk are correct,ie i aint getting the voice i still get the bells on some,and only get warnings on route(know were i went wrong with that.)i made a back up but it dont clear them out.
cheers. |
DennisN Tired Old Man
Posted: Thu Mar 22, 2007 8:23 am Post subject: |
to the forum.
Now please give us a bit more info on what you've done. ...
1. How did you do the backup? (using Tom Tom Home may not be a FULL backup, Windows Explorer SHOULD be, providing you were Showing All Files and Extensions. And the best backup of all is to copy your SD card, then use only the copy so that you can go back to the original card if necessary). I am hesitant to start advising on how to get back to your original state until I know how well you know to muck about with computer and 510.
2. Which cameras have you loaded - the ones from this site?
3. Where did you place the cameras?
4. How did you go about the voices?
5. Where did you place the voices?
6. Have you used or disabled the already included Tom Tom cameras? _________________ Dennis
Two of them are obesiting!! |
Posted: Thu Mar 22, 2007 8:31 am Post subject: |
Have a read of This Page:
#1 For Back-up, do this anyway - (before anything else)
#5 For spoken alerts
#13 For removal of TomTom speed cams.
In addition to the above have a look in your map folder using Windows Explorer, then delete any file with an extension of ov2 (these are the POI files).
Now download and install a fresh set of speed camera POI, configure them for warnings and give it a try (note to avoid using petrol checking its working) use Advanced Planning set a departure and destination that produces a route passing a camera. Then use Show Route Demo, set the speed to 100%(ish) and watch/ listen - The route speed can be a lot higher but using 100% will ensure the warning is given by the device (one less variable to contend with ) - Mike |
Posted: Thu Mar 22, 2007 10:36 pm Post subject: |
DennisN wrote: | to the forum.
6. Have you used or disabled the already included Tom Tom cameras? |
1 . back up was via tomtom home,
2 . they were from this site but thats were my problem started i done it a few weeks back and could not really remember witch ones i used.
3 . voices were from here but on install it asked me (on some )witch sound i wanted to use, after reading i then found out i have prob installed wrong voices for cameras.
4 . dont understand.
5 . into the same folder as maps/camaras.
6 . i did download the cameras from tomtom site only to find no mobile ones included,but have not disabled any.
cheers. |
Posted: Thu Mar 22, 2007 10:39 pm Post subject: |
mikealder wrote: | Have a read of This Page:
cheers lots of reading to do,thats my mistake i should have read this lot first, |
Posted: Fri Mar 23, 2007 8:01 am Post subject: |
cosworth4x4 wrote: | my mistake i should have read this lot first, |
Don't worry - your mistake would have been if you hadn't come here and simply flogged away in ignorance. Do as Mike says and you should be OK. But please don't be afraid to come back if it goes belly up again - we all get it wrong sometimes, so nobody will put you down if you do come back on it. From what you've said, you seem to have been very close to success originally anyway. _________________ Dennis
Posted: Sun Mar 25, 2007 10:19 pm Post subject: |
ok ive deleted the speed cameras and reinstalled them but i want to alter the distand i get the warnings and i set them to only warn on route,so i now dont get the warnings if they are on the bridges above motorways.
how do i alter this. |
Posted: Mon Mar 26, 2007 4:01 am Post subject: |
Go back to Change Preferences/ Manage POI/ Warn if POI on Route and re-configure each of your warnings, select the camera POI from the list, answer NO when it asks you to remove the POI warning, then set your new distance, and de-select the "Warn only if POI on Route" checkbox. Repeat the above for each camera POI you have installed - Mike |
Posted: Mon Mar 26, 2007 9:26 pm Post subject: |
cheers got it i was set to show fewer options,but im still geting asked what bell i want so ive still not got the corect voices some how.
ive used the zoned speed cameras and liz_m speed zoned.
any pointers cheers. |
Oldboy Pocket GPS Moderator
Posted: Tue Mar 27, 2007 7:20 am Post subject: |
cosworth4x4 wrote: | but im still geting asked what bell i want | In that case the ogg filename is not matching the OV2 filename.
Re-check that you have Un-ticked "Hide Extensions of Known File Types" in Explorer's Folder Options. You may have .ogg.ogg instead of .ogg! _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Tue Mar 27, 2007 9:23 pm Post subject: |
ok think im almost there im only getting asked the bell on pocketgps pmobile ones,they seem a repeat of the ones just listed as mobile . |
Posted: Tue Mar 27, 2007 9:32 pm Post subject: |
cosworth4x4 wrote: | ok think im almost there im only getting asked the bell on pocketgps pmobile ones,they seem a repeat of the ones just listed as mobile . |
No they are not a repeat, they are additional ones which haven't been checked for accuracy. Some people use them, others don't. If you don't want them, simply delete the OV2 files for all PMobiles. If you DO want to use them, either choose warning sounds for them, or download OGG files for the PMobiles and put them into the map folder like all the other OGG files. _________________ Dennis
Posted: Tue Mar 27, 2007 9:34 pm Post subject: |
ok cheers ill just add a bell in for them then,cheers for everyones help. |
