Pocket GPS World :: View topic - add camera facility
add camera facility
riddler
PostPosted: Tue Mar 27, 2007 8:07 pm    Post subject: add camera facility Reply with quote
Hi i have a tom tom 1 v2 software 6.56 is there anyway where you can have an add camera facility on this ie so you can just tap the icon and it records the location of the camera!The reason i ask is i used to have a go 300 and someone came up with software to use this facility,very useful.Thanks in advance.
Oldboy
PostPosted: Tue Mar 27, 2007 9:03 pm    Post subject: Reply with quote
POICapture is still with us, but unfortunately there appears to be a problem when trying to use it with the ONE NE using V6.56 Sad
riddler
PostPosted: Tue Mar 27, 2007 9:06 pm    Post subject: Reply with quote
oh better leave well alone then,can i just ask there are 2 new truvelo cameras appeared in my area barnsley today how do i capture the positions of these cameras,even if it means stopping alongside it,thanks!
Oldboy
PostPosted: Tue Mar 27, 2007 9:20 pm    Post subject: Reply with quote
There is a Google Map on the Submissions Page. Could you pinpoint the positions that way?
PostPosted: Wed Mar 28, 2007 1:43 pm    Post subject: Reply with quote
Don't forget the manual way of adding cameras too...
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&p=227626#227626
(my post page 5)
riddler
PostPosted: Thu Mar 29, 2007 8:48 pm    Post subject: Reply with quote
how can it be accurate having to click on a map,how do you know exactly where it is,isn,t it more accurate stopping at the side of the actual camera and sending the points in!I,m confused.
Oldboy
PostPosted: Thu Mar 29, 2007 9:00 pm    Post subject: Reply with quote
I didn't mean to confuse.
In the absence of being able to stop adjacent to the camera, which is the most accurate way, it is possible to get quite a good degree of accuracy on the map.
Following Andy's method, as linked to above, is a good way of doing it.
riddler
PostPosted: Thu Mar 29, 2007 9:08 pm    Post subject: Reply with quote
i have now submitted the camera using your map,used the points on it by stopping at the side of it,but not sure what the box "heading" means in degrees how do you find this out?thanks
Oldboy
PostPosted: Thu Mar 29, 2007 9:14 pm    Post subject: Reply with quote
It is intended to show the direction of travel of the vehicle when the camera would take the picture. On a Dual Carriageway it isn't so important.
The submission won't be rejected because you left that information out. Smile
Daggers
PostPosted: Fri Mar 30, 2007 12:46 am    Post subject: Reply with quote
There's an application called Quickam which can be found at http://www.automated.it/ttg-apps.html. It allows you to record cameras at your current location in a couple of screen-taps. It was originally written for TomTom v5.2, but I'm still using it quite successfully at v6.52. It doesn't record the same level of detail as POICapture, but it does store a POI location very quickly.
PostPosted: Fri Mar 30, 2007 12:51 am    Post subject: Reply with quote
That's good news Daggers. I thought that app didn't work with v6.
PostPosted: Fri Mar 30, 2007 2:51 pm    Post subject: Reply with quote
the submission page features 'tool tips' - hover the mouse cursor over any input section and it will show a description.
for heading this is: "Heading: the direction of travel in degrees (1-360)"
riddler
PostPosted: Fri Mar 30, 2007 7:51 pm    Post subject: Reply with quote
tes but where does it tell you the derees on the tom tom,mine only says n,w ,s and east
PostPosted: Sun Apr 01, 2007 1:02 am    Post subject: Reply with quote
Well, if you want, you CAN see the degrees heading on your TomTom - it's on the "configure GPS" page (where the satellite signal strength bars are).
But this isn't the sort of accuracy/detail they are looking for, just use the little compass chart next to the Heading box on the submission page to estimate it with reference to the road as shown on the Google map.
For example, if the road is going left to right across the page and you were travelling to the left, the heading is "90".
If the road is going diagonally up the page from, say, 7 o'clock on a clock face to 1 o'clock, and you were travelling up the page, then your heading is "22". Get it? Smile
RQ
PostPosted: Sun Apr 01, 2007 8:01 am    Post subject: Reply with quote
Hmmmmm...........???????? It was early
RQ
TT1v3 6.560 1713 UK&NI 660.1199
TTG700 6.520 1387 MoWE 660.1219
