Pocket GPS World :: View topic - when i try to unzip a file
adamst
PostPosted: Thu Mar 22, 2007 8:05 pm    Post subject: when i try to unzip a file Reply with quote
i download the file to the location on my computer yet it says when i try to extract files, Please insert multi-volume set and click on ok, well i dont have a disk all i wanna do is get the files.
any ideas???
PostPosted: Thu Mar 22, 2007 9:36 pm    Post subject: Reply with quote
What are you using to unzip the Files?
It's not an error message I'm familar with. Confused
What is 'the location' that you mention?
A bit more info will start us on the road to getting you up and running.Smile
TT Via 135 App 12.075: Europe Map v1135
PostPosted: Thu Mar 22, 2007 9:55 pm    Post subject: Reply with quote
back in the old days of floppy discs you could span zip files over multiple discs and if you didn't have all the parts you would get this error. quite how this has happened i'm not sure..
have you tried re-downloading it and trying again?
as oldboy says: what software are you using?
Tim Buxton
PostPosted: Thu Mar 22, 2007 10:14 pm    Post subject: Reply with quote
Even in the modern day, you can create multiple parts of a single zipfile. I understand that a certain 'quick share' site has a file limit of 100Mb, so spanning is a requirement.
Tim
Code_Cruiser
PostPosted: Sat Mar 24, 2007 1:36 pm    Post subject: Reply with quote
The PocketGPS website says that you must use the StuffIt software to unzip it rather than just using the standard windows method which would generate an error. I used the StuffIt software and it said that the zip file is corrupt! So seeking help!
PostPosted: Sat Mar 24, 2007 1:45 pm    Post subject: Reply with quote
On a Windows based PC you should use the zip software to unzip the files (note Windows XP can support extraction of files from zipped folders directly)
Stufit is for use with the mac platforms IIRC - Mike
JockTamsonsBairn
PostPosted: Sat Mar 24, 2007 3:27 pm    Post subject: Reply with quote
Can you give us a pointer to where you saw this, so that we can get it corrected?
Jock
PostPosted: Sat Mar 24, 2007 3:57 pm    Post subject: Reply with quote
You can find where that was typed Here - But as I said before it was with respect to using a mac based computer, so unless there are some instructions that are wrong elsewhere there isn't a problem - Mike
adamst
PostPosted: Sat Mar 24, 2007 5:10 pm    Post subject: Reply with quote
i am using a normal pc, and ie7. the only way i can dowload the files is by clicking in the show link box
PostPosted: Sat Mar 24, 2007 5:12 pm    Post subject: Reply with quote
That is how I have to download the POI files as well, its a known problem with IE7, you could always download and install FireFox - that works with the downloads section much better, otherwise just remember to click the check box for the link - Mike
aj2052
PostPosted: Sun Mar 25, 2007 2:54 am    Post subject: Reply with quote
Perhaps it should be mentioned the other well discussed problem when downloading combined sub categories, you may have a problem when downloading say shopping sub categories above approx 23 entries, you should then download2-3 sets and append them all in poiedit to combine them and save altogether,not forgetting to also use the show link method for each download.
22.094 (25 Sep 24)
