Pocket GPS World :: View topic - New User Setup
New User Setup
Carll
PostPosted: Sun Feb 29, 2004 12:28 pm    Post subject: New User Setup Reply with quote
Confused
I have just received my Axim X5, 256Meg CF card and tt2 software.
All appears to work, however....
I have installed all to the CF card, is this wrong?
The reason I ask is while disconnected from the GPS receiver the tt2 software will on occassions not be accessable, and the quick link on the front screen stops working. If I deselect this from being displayed, then reselect it it will start working again.
Most times clicking on start and tt2 will work, but this morning it did not until a soft reset.
I thought that the software would be fine without the GPS receiver connected, am I wrong, or have I done something wrong?
I have looked throught the pages and cannot find this answered anywhere else.
PostPosted: Sun Feb 29, 2004 6:29 pm    Post subject: Reply with quote
Don't worry, this is nothing serious.
The start menu gets created when the machine boots up. At that time it doesn't yet know that it has a CF card in the slot. Therefore any shortcuts that point to the CF card will not have the right icon associated. If you tap it it will work fine nonetheless.
The same problem occurs when you try to run programs on startup or on wakeup - when these programs are not in main memory then there is a good chance the PocketPC will not execute them - because it wakes up first and then re-connects to the storage card.
Let's call it a mild design flaw...
Carll
PostPosted: Wed Mar 03, 2004 8:45 am    Post subject: Update Reply with quote
Thanks for the reply, just to keep you updated, I reinstalled the application into the main memory, and the maps onto the CF card. This has fixed all the problems.
Thanks again.
Carl.
iPAQ 5550; 400MHZ - 256 SD Card - TT wired GPS - TTN3 UK - PPC 2003
PostPosted: Wed Mar 03, 2004 3:09 pm    Post subject: Reply with quote
It may have fixed the problem, but now you created anohter one - you have reduced the available RAM. So if you load larger maps or plan longer routes you will see the machine become unstable quicker..
a4ace
PostPosted: Thu Mar 04, 2004 2:40 pm    Post subject: Reply with quote
really? i thought it is recommended to install all ttn2 software in main memory, right down to voice files. i had problems when i installed everything to SD card.
tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb
PostPosted: Thu Mar 04, 2004 3:17 pm    Post subject: Reply with quote
That's not entirely true. Of course it depends on the SD card brand. SanDisk cards have a particularly bad reputation.
Even then - I am running all my programs off the (SanDisk) 256MB SD card, and haven't seen any issue with that yet. Of course it is iimportant to defragment the disk from time to time.
The only thing that you cannot install to the storage card (even though you may have specified that as the destination) is the TomTOm GPS driver. That one will always end up in the \windows directory.
Having everything on the storage card also has the advantage that you can be up and running quickly after a complete power outage. You make a full backup of the main memory to SD card (and this backup is pretty small since all the programs are on th ard already and don't need backup) and then when you had the power outage all you need to do is a restore of the main memory data from the SD card.
a4ace
PostPosted: Thu Mar 04, 2004 9:35 pm    Post subject: Reply with quote
damn right!!! moved '\program files\navigator' to '\cf card', modified shortcuts, modified registry settings that point to the voice files, and drove about 50kms. trouble free indeed!!! Thumbs Up
didn't try moving to '\sd card' as i already had problems with it.
i thought with more ram available, i would try running pocketmusic with tomtom. still didn't work. navigator freezes after 5mins.
PostPosted: Fri Mar 05, 2004 12:25 am    Post subject: Reply with quote
well, check if you can free up some more RAM with the same method. My MP3 player works just fine in the background
a4ace
PostPosted: Fri Mar 05, 2004 9:12 am    Post subject: Reply with quote
i've already freed up as much as i can. and allocated more memory to programs. may i ask what pocketpc you have? thanks.
PostPosted: Fri Mar 05, 2004 4:05 pm    Post subject: Reply with quote
My work horse is an iPAQ 3970, with PocketPC2002. I can't upgrade to WM2003 because my GSM/GPRS jacket doesn't support that.
You may have been trapped in the "32 process limit" situation. WM2003 is notorious for shortage of process slots. Can you check your \windows\startup folder and see if you can remove some of the startup items that you don't need?
a4ace
PostPosted: Fri Mar 05, 2004 5:50 pm    Post subject: Reply with quote
there's not much: bttrayce.lnk, fe_wa.lnk, and poutlook.lnk. i don't think it would do anything if i remove one or two.
could it be that the bluetooth gps takes up more resources than wired?
PostPosted: Fri Mar 05, 2004 5:57 pm    Post subject: Reply with quote
You should give it a try anyhow - every single process helps...
I don't know about the BT stack, but it may occupy more slots than a serial port. There alre alos some process viewers available for the PocketPC (for example as part of the embedded visual tools) - maybe that can give you a better answer.
a4ace
PostPosted: Sat Mar 06, 2004 7:26 pm    Post subject: Reply with quote
got hold of a process viewer. only about 14 processes with both tomtom and pocketmusic. i'm starting to conclude that the problem is the bluetooth gps driver. perhaps it freezes when interrupted while in the process of receiving data. i don't know... maybe the serial port has better handshake than bluetooth...
22.071 (03 Jul 24)
