adamst Occasional Visitor
Posted: Thu Mar 22, 2007 8:05 pm Post subject: when i try to unzip a file |
i download the file to the location on my computer yet it says when i try to extract files, Please insert multi-volume set and click on ok, well i dont have a disk all i wanna do is get the files.
any ideas??? |
Oldboy Pocket GPS Moderator
Posted: Thu Mar 22, 2007 9:36 pm Post subject: |
What are you using to unzip the Files?
It's not an error message I'm familar with.
What is 'the location' that you mention?
A bit more info will start us on the road to getting you up and running.![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Richard
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15158 Location: Bradford, West Yorkshire
Posted: Thu Mar 22, 2007 9:55 pm Post subject: |
back in the old days of floppy discs you could span zip files over multiple discs and if you didn't have all the parts you would get this error. quite how this has happened i'm not sure..
have you tried re-downloading it and trying again?
as oldboy says: what software are you using?
MaFt |
![](modules/Forums/images/avatars/483587116439494e7a5e13.jpg)
Posted: Thu Mar 22, 2007 10:14 pm Post subject: |
MaFt wrote: | back in the old days of floppy discs you could span zip files over multiple discs and if you didn't have all the parts you would get this error.
MaFt |
Even in the modern day, you can create multiple parts of a single zipfile. I understand that a certain 'quick share' site has a file limit of 100Mb, so spanning is a requirement. _________________ Tim |
Code_Cruiser Occasional Visitor
Posted: Sat Mar 24, 2007 1:36 pm Post subject: |
The PocketGPS website says that you must use the StuffIt software to unzip it rather than just using the standard windows method which would generate an error. I used the StuffIt software and it said that the zip file is corrupt! So seeking help! |
Posted: Sat Mar 24, 2007 1:45 pm Post subject: |
On a Windows based PC you should use the zip software to unzip the files (note Windows XP can support extraction of files from zipped folders directly)
Stufit is for use with the mac platforms IIRC - Mike |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Sat Mar 24, 2007 3:27 pm Post subject: |
Code_Cruiser wrote: | The PocketGPS website says that you must use the StuffIt software to unzip it rather than just using the standard windows method | Can you give us a pointer to where you saw this, so that we can get it corrected? _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sat Mar 24, 2007 3:57 pm Post subject: |
You can find where that was typed Here - But as I said before it was with respect to using a mac based computer, so unless there are some instructions that are wrong elsewhere there isn't a problem - Mike |
Posted: Sat Mar 24, 2007 5:10 pm Post subject: |
i am using a normal pc, and ie7. the only way i can dowload the files is by clicking in the show link box |
Posted: Sat Mar 24, 2007 5:12 pm Post subject: |
That is how I have to download the POI files as well, its a known problem with IE7, you could always download and install FireFox - that works with the downloads section much better, otherwise just remember to click the check box for the link - Mike |
aj2052 Frequent Visitor
Posted: Sun Mar 25, 2007 2:54 am Post subject: |
Perhaps it should be mentioned the other well discussed problem when downloading combined sub categories, you may have a problem when downloading say shopping sub categories above approx 23 entries, you should then download2-3 sets and append them all in poiedit to combine them and save altogether,not forgetting to also use the show link method for each download. |
