Pocket GPS World :: View topic - How do I remove maps?
dude100
PostPosted: Thu Mar 22, 2007 10:27 pm    Post subject: How do I remove maps? Reply with quote
Hi folks,
I have searched thoroughly but cannot find this anywhere so....
I have a Nuvi 300 and have been messing around with it and maps of Europe. Getting extra maps on is easy, but how the devil do I remove them again and just leave myself with the UK & Ireland base maps. The internal memory is almost full (should have bought as SD card first I suppose)
best regards and thanks.
Anita
PostPosted: Thu Mar 22, 2007 11:11 pm    Post subject: Reply with quote
I thought old maps were deleted when you loaded new ones, so if you now load UK & Ireland that's all there will be on the unit.
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
dude100
PostPosted: Thu Mar 22, 2007 11:37 pm    Post subject: Reply with quote
Hmmmm,
Thanks Anita, now the unit says it only has v9 UK & Ireland, but the internal memory has 396 mb used and only 19mb free. I thought there would have been a lot more free space with only the above maps installed?
dude100
PostPosted: Fri Mar 23, 2007 12:03 am    Post subject: Reply with quote
Just thought I would update this....
After installing a bit if Italian map from mapsource onto the SD card, a single file named gmapsupp.img appeared.
When I checked the internal memory of the unit itself there was also a file of the same name.
Assuming the gmapsupp.img was an addition (supp = supplementary?) I copied it off the internal memory and started up the unit, then lo, maps are fine and free space has appeared!
Anita
PostPosted: Fri Mar 23, 2007 12:16 am    Post subject: Reply with quote
dude100 wrote:
Assuming the gmapsupp.img was an addition (supp = supplementary?) . . .
No, gmapsupp.img is the file containing all the mapping installed to the unit or card.
Anita
UK map 1130.12368
Samsung Galaxy S21
dude100
PostPosted: Fri Mar 23, 2007 12:57 am    Post subject: Reply with quote
I have double checked Anita and the mapping it places on the sd card has the same file name & extension and can be deleted off the card with no effect on the main maps.
Without the file the unit is still working fine and I have the right amount of free space now, but lesson learned so everything will go on the sd card from now on.
regards.
Anita
PostPosted: Fri Mar 23, 2007 8:45 am    Post subject: Reply with quote
The gmapsupp.img file on the unit contains all the maps on the unit and the gmapsupp.img on the card contains all the maps on the card. It is not a file of supplementary maps.
But as the unit's woking Ok now it doesn't really matter! :D
Anita
UK map 1130.12368
Samsung Galaxy S21
