normanlavender Occasional Visitor
Posted: Thu Mar 22, 2007 10:33 am Post subject: P350 power problem |
If I leave my P350 switched off and not connected to a power source, within 24 hours it will fail to switch on. The only way I can recover it is to connect it to a power supply and then I can switch in on OK.
I previously had a Mio 168 - I could leave this for a week without there being a problem.
Has anyone else experienced similar problems with the P350? |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Thu Mar 22, 2007 10:27 pm Post subject: |
There's a Mio patch click HERE _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Posted: Thu Mar 22, 2007 10:31 pm Post subject: |
And I meant to add, Activesyc starts running in the background on it's own but you can resolve the problem as follows:-
Start your P350/P550.
Go to Start – Programs – Activesync.
Tap on Menu then Add Server Source’
Enter 1, 1, 1, 1 as the server.
User a
Password b
Domain c
Next uncheck the boxes
End.
Now go back to Menu – Schedule and use the two sliders to select each as Manual
OK
Now go to Activesync - Options, where you can delete the Server you’ve just added. It will now keep the Manual settings.
You will still be able to use Activesync in the normal way but you’ll find it no longer auto-starts when it’s left alone, thereby saving some battery power.
Mio recommend a ‘top-up’ at least once per week. _________________ Formerly known as Lost_Property
Posted: Thu Mar 22, 2007 11:02 pm Post subject: |
Many thanks for your quick response. Presumably I just unpack the executable from the zip file and run on my PC with the P350 connected via activesynch? |
Posted: Thu Mar 22, 2007 11:12 pm Post subject: |
Quote: | Presumably I just unpack the executable from the zip file and run on my PC with the P350 connected via activesynch? | That's right.
When I downloaded I saved the file in case I do a re-install and then find the patch no longer available on the Mio site. ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Formerly known as Lost_Property
