rufford Occasional Visitor
Posted: Sun Mar 18, 2007 4:23 pm Post subject: |
Just installed the voice alerts on my tomtom one v2 and all appears working well except that in addition to the 6 files 20 to 70 mph pmobile not being on vioce alert which I understand is normal, there are also "pmobile tba" and "mobile var"also not on voice alert. Is this correct? |
Posted: Sun Mar 18, 2007 4:33 pm Post subject: |
pmobile tba is a pmobile file so there will not be spoken voice warnings for these cameras at the moment.
The mobile var camera category contains nothing so I would delete it from your device - it is a file the site creates, but no such camera exists, there is no point consuming one of you 100 available custom POI categories with a file that contains no data - Mike |
Posted: Sun Mar 18, 2007 4:37 pm Post subject: |
Forgot to say that I have the speed zoned version installed on myTT1V2 and how much better the voice alerts are as "Liz" now tells me the camera type and speed limit and you do not have to look at the sat nav at all for the info :D . |
Darren Frequent Visitor
Posted: Mon Mar 19, 2007 9:00 pm Post subject: |
wibbly wrote: | In the Text to Speech “Crystal” PMobile Version
With chime:
Speed-zoned version
they seem to be without a chime... |
Now resolved, apols for the confusion but all the with/without, speedzoned tec gets a bit confusing after a while!
Also resolved an error with the chime pmobile consolidated link as well oh and added install guide for Route66 (courtesy of MikeA) ![Smile](modules/Forums/images/smiles/icon_smile.gif) _________________ Darren Griffin |
Andy_P Pocket GPS Moderator
Posted: Tue Mar 20, 2007 5:31 pm Post subject: |
Darren wrote: |
Now resolved, apols for the confusion but all the with/without, speedzoned tec gets a bit confusing after a while! |
You can say that again! Was going gaga at times, trying to work out a "unified" naming system!
Just out of interest, were they my errors or just the links going wrong? |
Posted: Tue Mar 20, 2007 6:54 pm Post subject: |
Andy_P2002 wrote: | You can say that again! Was going gaga at times, trying to work out a "unified" naming system!
Andy they were entirely my error! Just go a bit word blind after a while! _________________ Darren Griffin |
Posted: Tue Mar 20, 2007 7:11 pm Post subject: |
Phew! ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
trout Occasional Visitor
![](modules/Forums/images/avatars/gallery/024.gif)
Posted: Thu Mar 22, 2007 10:33 am Post subject: |
trout wrote: | mikealder wrote: | Darren wrote: | It is working on all TomTom Version 6 platforms. The distance is configurable, it's only if you use TomTom's own camera database where this is fixed. |
Don't forget though if you are using TomTom version 5,x (where x can be anything from 0 upwards) on a PNA or PDA the ogg file method will also work (but only with the PocketGPSWorld database) - only the TomTom Mobile 5 and Palm versions appear not to work with this audio warning method - Mike |
With TTN5 do you need to reinstall the original Data CHK file?
Which was replaced when I installed Rays voice file |
Problem with VICKI Speedzoned just been out in the car and no voice but a series of chimes,jangles etc Whereas the pmobile work perfectly is it me or you
Many thanks anyway _________________ TTXL IQ Routes |
Posted: Thu Mar 22, 2007 11:31 am Post subject: |
If you're getting chimes, jangles etc then it must be you, I'm afraid
Double check the "Warn when near" settings for the camera types that aren't working. Unless you have a 910, it should skip the step where it asked for a sound - this shows the new sound file has been recognised.
But you DO need to go through this step for every camera type.
As for the general question about reverting to the original data.chk - you don't NEED to do that, it just means you have the original sounds back for use with any other POIs if you wish. |
Posted: Thu Mar 22, 2007 12:04 pm Post subject: |
Andy_P2002 wrote: | If you're getting chimes, jangles etc then it must be you, I'm afraid
Thank you
Have rechecked "warn when near " settings is there anyway of checking without actually being near the poi concerned ? all files look OK in the map folder also as stated before p/mobile sounds OK
Am using PDA with TTN5
Thanks _________________ TTXL IQ Routes |
JockTamsonsBairn Lifetime Member
![](modules/Forums/images/avatars/202069601647f4a51ae4e4d.jpg)
Posted: Thu Mar 22, 2007 1:25 pm Post subject: |
trout wrote: | Andy_P2002 wrote: | If you're getting chimes, jangles etc then it must be you, I'm afraid
Thank you
Thanks |
mikealder wrote: | You can use advanced planning (AtoB) to set a departure and destination, make sure your route passes a camera (or select a specific camera as the departure point or destination) - then use route demo to replay the route at 100% speed (ish) this is a less costly option than burning petrol checking out your settings - Mike |
mikealder wrote: | It will work at a higher speed - somewhere around 300% IIRC - but to make sure its best to use prototypical speeds i.e. 100% when troubleshooting - Mike |
_________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Thu Mar 22, 2007 1:41 pm Post subject: |
Should have thought of that myself _________________ TTXL IQ Routes |
AndyFPritchard Occasional Visitor
Posted: Thu Mar 22, 2007 11:11 pm Post subject: |
Ive tried downloading the voice prompts on my RZ1710 on TTNav but everytime I am asked to assign a tone. In the instructions it covers this and Ive checked Ive copied them to the right place and that the the names match. Everything seems as it should. Any ideas or is it just that the version on TT Iam using is too old and doesnt support these files. ![Question](modules/Forums/images/smiles/icon_question.gif) |
Posted: Thu Mar 22, 2007 11:48 pm Post subject: |
AndyFPritchard wrote: | Ive tried downloading the voice prompts on my RZ1710 on TTNav but everytime I am asked to assign a tone. In the instructions it covers this and Ive checked Ive copied them to the right place and that the the names match. Everything seems as it should. Any ideas or is it just that the version on TT Iam using is too old and doesnt support these files. ![Question](modules/Forums/images/smiles/icon_question.gif) | Which version of TTNav are you using? _________________ Jock
Posted: Fri Mar 23, 2007 12:05 am Post subject: |
Version 4.440 |
