Pocket GPS World :: View topic - TomTom Custom Voice Alert Download Page Added
Goto page Previous  1, 2, 3, ... 15, 16, 17  Next
rufford
PostPosted: Sun Mar 18, 2007 4:23 pm    Post subject: Reply with quote
Just installed the voice alerts on my tomtom one v2 and all appears working well except that in addition to the 6 files 20 to 70 mph pmobile not being on vioce alert which I understand is normal, there are also "pmobile tba" and "mobile var"also not on voice alert. Is this correct?
PostPosted: Sun Mar 18, 2007 4:33 pm    Post subject: Reply with quote
pmobile tba is a pmobile file so there will not be spoken voice warnings for these cameras at the moment.
The mobile var camera category contains nothing so I would delete it from your device - it is a file the site creates, but no such camera exists, there is no point consuming one of you 100 available custom POI categories with a file that contains no data - Mike
rufford
PostPosted: Sun Mar 18, 2007 4:37 pm    Post subject: Reply with quote
Forgot to say that I have the speed zoned version installed on myTT1V2 and how much better the voice alerts are as "Liz" now tells me the camera type and speed limit and you do not have to look at the sat nav at all for the info :D .
PostPosted: Mon Mar 19, 2007 9:00 pm    Post subject: Reply with quote
wibbly wrote:
In the Text to Speech “Crystal” PMobile Version
With chime:
Speed-zoned version
they seem to be without a chime...
Now resolved, apols for the confusion but all the with/without, speedzoned tec gets a bit confusing after a while!
Also resolved an error with the chime pmobile consolidated link as well oh and added install guide for Route66 (courtesy of MikeA) Smile
PostPosted: Tue Mar 20, 2007 5:31 pm    Post subject: Reply with quote
You can say that again! Laughing Was going gaga at times, trying to work out a "unified" naming system!
Just out of interest, were they my errors or just the links going wrong?
PostPosted: Tue Mar 20, 2007 6:54 pm    Post subject: Reply with quote
Andy they were entirely my error! Just go a bit word blind after a while!
PostPosted: Tue Mar 20, 2007 7:11 pm    Post subject: Reply with quote
Phew! Wink
trout
PostPosted: Thu Mar 22, 2007 10:33 am    Post subject: Reply with quote
trout wrote:
mikealder wrote:
It is working on all TomTom Version 6 platforms. The distance is configurable, it's only if you use TomTom's own camera database where this is fixed.
Don't forget though if you are using TomTom version 5,x (where x can be anything from 0 upwards) on a PNA or PDA the ogg file method will also work (but only with the PocketGPSWorld database) - only the TomTom Mobile 5 and Palm versions appear not to work with this audio warning method - Mike
With TTN5 do you need to reinstall the original Data CHK file?
Which was replaced when I installed Rays voice file
Problem with VICKI Speedzoned just been out in the car and no voice but a series of chimes,jangles etc Whereas the pmobile work perfectly is it me or you
Many thanks anyway
TTXL IQ Routes
PostPosted: Thu Mar 22, 2007 11:31 am    Post subject: Reply with quote
If you're getting chimes, jangles etc then it must be you, I'm afraid Wink
Double check the "Warn when near" settings for the camera types that aren't working. Unless you have a 910, it should skip the step where it asked for a sound - this shows the new sound file has been recognised.
But you DO need to go through this step for every camera type.
As for the general question about reverting to the original data.chk - you don't NEED to do that, it just means you have the original sounds back for use with any other POIs if you wish.
trout
PostPosted: Thu Mar 22, 2007 12:04 pm    Post subject: Reply with quote
Thank you
Have rechecked "warn when near " settings is there anyway of checking without actually being near the poi concerned ? all files look OK in the map folder also as stated before p/mobile sounds OK
Am using PDA with TTN5
TTXL IQ Routes
JockTamsonsBairn
PostPosted: Thu Mar 22, 2007 1:25 pm    Post subject: Reply with quote
Thank you
mikealder wrote:
You can use advanced planning (AtoB) to set a departure and destination, make sure your route passes a camera (or select a specific camera as the departure point or destination) - then use route demo to replay the route at 100% speed (ish) this is a less costly option than burning petrol checking out your settings - Mike
mikealder wrote:
It will work at a higher speed - somewhere around 300% IIRC - but to make sure its best to use prototypical speeds i.e. 100% when troubleshooting - Mike
Jock
trout
PostPosted: Thu Mar 22, 2007 1:41 pm    Post subject: Reply with quote
Should have thought of that myself
TTXL IQ Routes
AndyFPritchard
PostPosted: Thu Mar 22, 2007 11:11 pm    Post subject: Reply with quote
Ive tried downloading the voice prompts on my RZ1710 on TTNav but everytime I am asked to assign a tone. In the instructions it covers this and Ive checked Ive copied them to the right place and that the the names match. Everything seems as it should. Any ideas or is it just that the version on TT Iam using is too old and doesnt support these files. Question
JockTamsonsBairn
PostPosted: Thu Mar 22, 2007 11:48 pm    Post subject: Reply with quote
Which version of TTNav are you using?
Jock
AndyFPritchard
PostPosted: Fri Mar 23, 2007 12:05 am    Post subject: Reply with quote
Version 4.440
Page 2 of 17
