Geordie_the_parrot Occasional Visitor
Posted: Mon Jul 05, 2004 3:19 am Post subject: |
ooops, Sorry about the size of the text in that last post. |
Altius Occasional Visitor
Joined: 30/07/2003 12:30:27 Posts: 4 Location: Netherlands
Posted: Mon Jul 05, 2004 9:31 am Post subject: |
1. UNCHECK Receiving All beams and you will be able to use the checkbox at the TomTom GPS utility. Use NMEA 0183v2 4800 and Native IR: and you should be fine.
2. If the Haicom GPS receiver does not start flashing, it either does not have power or it is broken. When the red led starts flashing it is looking for satelites but does not have a fix yet. When it has a fix the red led will stop flashing and illuminate continuesly.
3. See 1.
Hope this helps. |
Posted: Mon Jul 05, 2004 1:01 pm Post subject: |
Thanks Altius,
I just tried all you suggested but still no success.
I left it ON for 10 minutes but it still didn't find any sats.
Thinking that the problem was with the IR, I opened up the settings and put the tick back into the "Receive all data" box, checked that the Haicom was still on the same settings with the box ticked, and tried again.
Still nothing.
I did see the red lights flashing on the mouse though.
I have used the same Haicom GPS unit with an Ipaq 3630 in the same location so actually seeing the sats isn't the problem.
Any more clues, or have I just got a dodgy unit?
Cheers,
Steve |
Posted: Mon Jul 05, 2004 1:22 pm Post subject: |
If your Haicom is flashing then there should be data being send out to the Ipaq. To check you can try two things:
1st: to check if IR data is send out at all: use a digital camera or web cam and point it to the IR-led sending out data. You will have to see a white light being send out of the IR-led. If it doesn't, your unit doesn't work.
2nd: if the first step was successfull, install a terminal emulator program on your PDA (like Pocketty from Dejavu which has a five minute trial version) and configure it to open the Native IR: port at 4800 baud, no parity, 8 bits, 1 stopbit. If you look at the data appearing on the screen it should look something like:
$RMVTG,455,3456,56,45678,4466,46
$RM...........
without any strange charaters.
If this is the case everything is working correctly and you have a TomTom config issue.
Hope this helps. |
DavidW Pocket GPS Moderator
Posted: Mon Jul 12, 2004 12:21 pm Post subject: |
I've edited out the "size" element of your first post, geordie - I hope that helps everyone.
Are we sure that "Native IR" is the right port setting? That sounds like it could be a raw IR setting. On most iPAQs (though I'm not familiar with the 1910), the 'cooked' IrCOMM port has a COM port number - often COM2: or COM3:.
It may be worth trying any other selectable COM ports - it can't hurt, anyway.
David |
palmony Occasional Visitor
Posted: Wed Jul 14, 2004 11:21 am Post subject: Portable power supply |
Is there a portable power supply to be connected to this gps for walking navigation?
Thanx
Palmony |
chris_s Occasional Visitor
Posted: Sun Feb 13, 2005 10:15 pm Post subject: Haicom's InfraRed GPS kit for the iPAQ 1910 |
Can anyone confirm whether the kit is compatible with copilot live pocket pc 5? I've seen loads of conflicting advice on other forums - so I was advised to try you guys.
Chris |
ampelmann Occasional Visitor
Posted: Fri Jun 10, 2005 3:05 pm Post subject: Review |
can someone tell me if this infrared connection is reliable? Can you use it in sunlight without any problems? Is there anything else negative about this cradle? Please give me a short review.
Thank you very much!
Marc |
womersley999 Occasional Visitor
Posted: Mon Jun 13, 2005 5:07 pm Post subject: ipaq 1930 with haicom gps |
hi,
I have a ipaq 1930 and have purchased a acc pda haicom amplified infrared mount for the 1900 series.
Everything seems to be working but I do not get the signal through to the ipaq.
I have tried the setttings suggested all ready without success so can someone advice me.
If I set it to haicom gps and bluetooth the gps box on the ipaq will not tick and it states unit disabled.
any assistance would be appreciated. |
Posted: Wed Jun 15, 2005 6:08 pm Post subject: |
hi,
I had the gps unit upside down when in the car so it continuously flashed.
Had the wrong setting in the ipaq. changed it to s2410 irda2410 and liftoff.
brilliant. |
Whitters Occasional Visitor
Posted: Mon Jul 04, 2005 6:21 pm Post subject: HELP! |
I am desperatley lokign around to find somewhere that has theese in stock. Please can someone help!? ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
jonsegal Occasional Visitor
![](modules/Forums/images/avatars/11796318414301fa5686248.jpg)
Joined: 28/03/2003 10:54:36 Posts: 7 Location: United Kingdom
Posted: Mon Jul 11, 2005 3:32 pm Post subject: Infrared Pod Repair Service |
Hi everyone,
If you have a faulty infrared pod for your Haicom mount, I can offer a repair service, replacing the old infrared transitter with a new high quality, high intensity transmitter.
If you needing a repair, please email me at repair@tjskaraoke.co.uk |
Crog Occasional Visitor
Posted: Sat Mar 17, 2007 8:32 pm Post subject: |
Gotot www.northpeaks.com and you can find haicom products there. I bought my 701 unit there and i love it. Who says you can't get GPS on 1910 unit.. ![Laughing Out Loud](modules/Forums/images/smiles/icon_lol.gif) |
