Pocket GPS World :: View topic - Merging (aerial photo) maps
MrT
PostPosted: Fri Jan 23, 2004 9:10 am    Post subject: Merging (aerial photo) maps Reply with quote
When two aerial maps are merged that are vertically adjacent, the merged map always has part missing. On the seam of the maps, the maps meet at each end but in the middle there is a white gap of some 250 metres of missing land. This information that is missing from the merge comes from the lower of the two maps and is present on the original, ie the gap is not due to a projection distortion but missing data from the merge.
If you have Region 4 Photo take a look at OS grid TL65,98 it seems a little odd.
PostPosted: Wed Feb 04, 2004 8:31 pm    Post subject: Reply with quote
Merging maps is not something I have needed to do until this week. The OS maps always seem to give me the right coverage in the middle of the map area.
Things changed this week when I needed to merge 2 sections of Nautical charts in the Florida Keys. These merged perfectly.
I suspect (but can't prove) that what is happening is that the Aerial Photos have blank calibrated collars which MM sees as being part of the map. When it overlays them and matches them up the blank collar is clearly visible. Does your blank area extend all the way across the join? If it does then this would be pretty conclusive.
MrT
PostPosted: Mon Feb 16, 2004 10:26 am    Post subject: Blank Area Reply with quote
The aerial photos meet at the ends of the join but there white gap is in the middle.
A horizontal merge works OK.
According to memory map support the aerial photos are not meant to be merged.
TigerMoff
PostPosted: Fri Feb 20, 2004 4:24 pm    Post subject: Reply with quote
You will find that it is due to the curvature of the earth that there a gaps between the tiles (not missing sections). Memory map gets the top and bottom ends of the tile and joins them thus making a bow in the middle. This only happens in the 2004 OS edition since the calibration function was removed.
MrT
PostPosted: Mon Feb 23, 2004 8:07 pm    Post subject: Reply with quote
No, there is definitely missing image data at the join, images that are there on the original aerial photo's are missing on the the "gap" in the merged. It is not a gap between the two sets of data as would be caused by map curvature.
It is also nothing to do with the OS2004 program as compared to other versions. The 2003 versions do the same, as does the (non-OS) Memory Map Navigator 4.00 Build 345 2004 version which still has the calibration function.
TigerMoff
PostPosted: Fri Feb 27, 2004 2:29 pm    Post subject: Reply with quote
Im sorry but I think we will have to agree to disagree on this one then. I have been able to merge maps with out any problem in the 2003 software using the 2003 maps.
MrT
PostPosted: Sun Feb 29, 2004 5:27 pm    Post subject: TigerMoff Reply with quote
Can you let me know which Aerial Photo tiles you merged (vertically) so that I can try it with 2003? It may be that it only affects certain tiles?
Horizontal photo tile merges or maps where boundaries overlap by 20km have no problem.
TC
PostPosted: Wed Mar 03, 2004 1:02 pm    Post subject: Reply with quote
I also tried merging maps together and I am not impressed.
I have 2003 and tried merging UK(OS) regions (south-west, south wales - 1 and 3 I think) and got a big white gap. Yes I think the the map projection UTM is not applied correctly. It looks like on region gets the projection but the other is treated like a rectangular bitmap. In fact MM in my experience only realy likes dealing with one of anything e.g. one map (can be displayed) one elevation model (can be displayed) one places names.
I haven't tried this but I think if your meger maps successfully you will NOT get a merged elevation model or place name database. I'd like to be proved wrong.
Having said this I'd would like to say the I really like MM - it's by far and away better that Fugawi.
23.092 (10 Sep 25)
