Durotriges Regular Visitor
Posted: Mon Mar 12, 2007 9:33 pm Post subject: Advanced Planning - Screen Re-Draw Now Very Slow. |
I've just added the European maps to my TomTom5/iPaq and now whilst in Advanced Planning, when zoomed right out on the map browsing screen, it takes ages to re-draw the screen when I scroll about - maybe as long as a minute.
When I just had the UK map installed, plus major routes in Europe I could scoot about the map browsing screen in and around Europe as quickly as I wanted to.
I presume this is because it is now having to fill in loads of detail now that I have the full Europe maps installed, but I don't understand why it has to do this because I have only selected the UK Plus map. I would have expected it to be as fast as before because I only have the UK Plus map selected - the same situation as when it used to scroll quickly.
Is this normal?
Thanks very much,
Mike |
Calomax Lifetime Member
![](modules/Forums/images/avatars/10616504774a6a18ca3ea50.jpg)
Posted: Wed Mar 14, 2007 9:50 am Post subject: |
It's probably because the plus map has much of the same detail as the Western Europe map to draw. On TTN5 my device took close on a minute to draw the map and also to plan a route if it was a long one. TTN6 is considerably faster even though I'm now using the Western Europe map.
Hope that helps ![CoPilot](modules/Forums/images/smiles/custom19.gif) _________________ TT Go Essential |
Posted: Wed Mar 14, 2007 3:23 pm Post subject: |
Thanks for you reply :D. I suppose I'll have to put up with it then! It's only when I've zoomed out to show most of Europe, then if I try to scroll across it will take ages to re-draw the screen.
It is now showing the red blotches of built-up areas on mainland Europe (with only UK Plus selected) so it must be dealing with extra detail. The only thing that doesn't make sense is that I've only got the UK Plus map selected, so I wouldn't expect TomTom to be trying to show loads of detail when zoomed out to Europe level. With UK Plus selected and no European maps installed there was no problem.
Mike |
Posted: Thu Mar 15, 2007 9:29 am Post subject: |
I don't understand why having the WE map installed but not selected makes a difference. It might be worth trying the simple UK map instead of UK Plus, then select WE if you want to see Europe. Alternatively I suppose you could move the WE map onto your PC and just shift it back when you need it. It's quick to do if you use a card reader.
Maybe someone else out there knows the answer :P _________________ TT Go Essential |
Posted: Fri Mar 16, 2007 1:01 am Post subject: |
I've got a card reader on its way to me now. I'm not going trough all that wait again, installing maps via ActiveSync! It must have taken about 7 hours to put all the maps on!
It's definitely showing more detail in Europe (built up areas speckled across the map in red, when zoomed right out), but as you say, it doesn't make sense why that should be included if only UK Plus is selected.
I'll experiment a bit more when my card reader turns up!
Mike
:D |
