silverfoxcc Occasional Visitor
Posted: Sat Mar 10, 2007 6:51 pm Post subject: TT5 Postcode search |
When i enter a postcode (RG12 4UZ), nothing else seems to happen, should the system default to the street and then ask for the number?, or am i expecting too much?
The nearest i can get is to scroll down to the address where RG124 is shown and then find the address as it is with the city search!
Also can i cut the voice directions down but have a loud notice for the cameras?
Thanks |
Posted: Sat Mar 10, 2007 6:56 pm Post subject: |
What device are you using the TTN5 software on?
If its a PDA you need to add a folder named tomtom to the root of the memory card, don't leave a space in the postcode just enter it as seven digits RG124UZ and it should work - assuming you have installed the postcode data from the disk - this resides in a folder named zip in the root of the memory card.
For the voices you can install a silent voice so you get no directions but full volume for spoken camera alerts, have a look at Ray's site Here - Mike |
Posted: Sat Mar 10, 2007 10:27 pm Post subject: |
Mike, I am on a Dell X5. When i go onto the CF card i show two floders, i is Great britain map, the otheris the GB postal file (which i assume is the postcode one?)
THE GB map has all the pio .incl the gatsos and sevral others.
I have made a new folder in this file marked tomtom and transferred the zip file to it. However when i enter a postcode in the postcode line at top of pda it still sits there after i have entered the full postcode. soory to appear dense on this but should i unzip the file into the tom tom folder?
I did download the postcode file off of the tomtom CD
Oh and thanks for the site to visit |
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Sat Mar 10, 2007 11:02 pm Post subject: |
You appear to be entering the postcode in Navigate to Address
Instead go to the next page and choose Postcode.
The tomtom folder needs to remain empty.
The zip folder just needs to go on your card. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
Oldboy Pocket GPS Moderator
Posted: Sun Mar 11, 2007 10:18 am Post subject: |
silverfoxcc wrote: | I have made a new folder in this file marked tomtom and transferred the zip file to it. | Both the TomTom and Zip Folders go into the Root of the SD Card. Not into any other Folder. _________________ Richard
TT Via 135 App 12.075: Europe Map v1140 |
Posted: Sun Mar 11, 2007 9:42 pm Post subject: |
Thank, i must be a real muppet on this, as i dont follow what the root directory is!!
First, i have used the postcode , and get the word postcode along the top, with 1-5 and 6-0 below the wite area, and then thw alphabet. When i put the postcode in the top line, nothing happens!. should it default to the road mthe postcode covers and ask for a number?
second, i have connected the pda to the pc and examined the CF card that has the info on. I click on my pocket pc, then CF card, this brings up two folders Great Britain map, which has all the files inc the poi and ov2 files. The other says zip. clicking on this bring up a file marked great britian postal double left click on this icon shows it to be
type postal file
location \cf card\zip
size 8.41mb
i cannot unzip this
Are these files in the correct location, if not under what heading/file should they be filed
Ron |
Posted: Sun Mar 11, 2007 10:24 pm Post subject: |
silverfoxcc wrote: | First, i have used the postcode , and get the word postcode along the top, with 1-5 and 6-0 below the wite area, and then thw alphabet. When i put the postcode in the top line, nothing happens!. should it default to the road mthe postcode covers and ask for a number? | When you have input the Postcode, using the keyboard, there should be a List, starting with the Postcode you typed in, in the 'white area'.
Tap this entry and you will progress to the next screen.
silverfoxcc wrote: | second, i have connected the pda to the pc and examined the CF card that has the info on. I click on my pocket pc, then CF card, this brings up two folders Great Britain map, which has all the files inc the poi and ov2 files. The other says zip. clicking on this bring up a file marked great britian postal double left click on this icon shows it to be
type postal file
size 8.41mb
i cannot unzip this
Are these files in the correct location, | That's correct. That is the Root of the Card. The highest level you can get. _________________ Richard
Posted: Mon Mar 12, 2007 12:47 am Post subject: |
Richard,
I go to the postcode section, and type in the code ,say CT5 4TR, in the postcode line, it then shows me in the 'white'section, a list of postcodes
CT5 1 (Whitstable)
CT5 2 (Whitstable)
CT5 3 (Whitstable) etc etc
Selecting CT5 4 it then gives a list of roads starting with
A290
A299
A2990
Acton Road CT5 etc etc
This happens wheter i do the postcode as CT54NR or CT5 4NR except that with the one with a gap it shows CT5 4 as first choice.
So i have to scroll down to Nightingale Ave and selct the house number, which i could have done anyway by using the address. icon
Any idea where i (or the program) is going wrong, as in its present state i cant seen any use for it!!
Ron |
Posted: Mon Mar 12, 2007 8:47 am Post subject: |
Ron, What hardware are you using the TomTom software on, also can you let us know the version (tap the sat strength meter, and you will see the version on the right side of the screen).
I have seen this behaviour with version 5,0 on devices with built in keyboards before, might not be the case he but worth checking - Mike |
Posted: Mon Mar 12, 2007 10:43 am Post subject: |
This is what happens when the TT can't find the ZIP Folder.
The usual remedy is the empty TomTom at the same level as the ZIP Folder.
Just create a Folder on the Card and call it TomTom. IIRC that is the way you have to name it. _________________ Richard
Posted: Mon Mar 12, 2007 1:20 pm Post subject: |
Version is 5.000, and the CF card now has 3 folder, the GB, the zip, and Tomtom, which is empty
Am i doing ok? |
Posted: Mon Mar 12, 2007 3:59 pm Post subject: |
Looking good.
What's the bad news?;) _________________ Richard
Posted: Mon Mar 12, 2007 5:00 pm Post subject: |
No bad news, when i put in the postcode it comes up with the streetname. Hurrah!!
Mind, i cant fathom out how adding an empty folder cured it, but i am not going to lose any sleep over it
Thanks to all who assisted me
Was well appreciated, |
billyking Occasional Visitor
Posted: Mon Apr 09, 2007 1:48 am Post subject: |
hello
i've had the same problem as above (only the first 3 or 4 digits of the postcode are accepted) but put it down to my version of tomtom
after reading this,i'm not so sure so i tryed moving the zip file but it dont make any difference
anybody know if my version has 7 digit postcode search and how to get it working if so
pocketpc device
app version 6.000 (7370)
free ram 7.6 mb
gps driver v1.20
map:GB_plus_major_roads_WE
V650.1046
running on an ipaq 3715
i had it about 3 months now so still working out how to use it ,
cheers for looking |
Posted: Mon Apr 09, 2007 7:05 am Post subject: |
billyking wrote: | anybody know if my version has 7 digit postcode search and how to get it working if so | Your setup has 7 digit capability.
Have you followed the instructions above with regard to the empty TomTom Folder? _________________ Richard
