busman40 Occasional Visitor
Posted: Sat Mar 10, 2007 11:50 am Post subject: POI Pictures |
I have a Tom Tom 300 and have quite a number of poi`s on it. The problem is that some of the poi`s have the same icon on the map (an orange square with a black star in middle) and therefore i do not know what the poi is. Can you change the icons and how do you do it if possible? I would be grateful for any help. :D [/size] |
Posted: Sat Mar 10, 2007 12:02 pm Post subject: |
Those are default icons which means that there is no .bmp file of the same name as the POI file (barring extension, of course) in the Map directory. The answer is to put in the .bmp file supplied with the POI or make your own. _________________ Tim |
tonys66 Lifetime Member
Posted: Sat Mar 10, 2007 12:04 pm Post subject: |
All pois you make up can have there own bmp just make sure the ov2 and bmp file have the same name for each file ie
homebase bmp & homebase ov2
dixons bmp & dixons ov2
you can make these in paint make them in 22x22 size
If you say what you want i might be able to email you the ones you want |
Posted: Sat Mar 10, 2007 2:42 pm Post subject: |
Thanks for your replies, here is a list of the current poi`s using same icon on my unit;
Amusement parks
Broadcasters
Cashpoints
Fast food restaurants
Lpg
Pubs
Station service
Waitrose.
As you can see it gets a bit confusing with the same icon |
JockTamsonsBairn Lifetime Member
Posted: Sat Mar 10, 2007 4:07 pm Post subject: |
busman40 wrote: | Thanks for your replies, here is a list of the current poi`s using same icon on my unit;
Amusement parks
Broadcasters
Cashpoints
Lpg
Pubs
Station service
Waitrose.
As you can see it gets a bit confusing with the same icon | Are these built-in POIs or the ones downloaded from here? The ones from here should have a separate BMP for each category. _________________ Jock
TomTom Go 940 LIVE (9.510, Europe v915.5074 on SD & 8.371, WCE v875.3613 on board) |
Posted: Sat Mar 10, 2007 4:22 pm Post subject: |
They were downloaded from POIhandler.com and only when put on unit did i see the matching icons. Can i download them from here because i have had trouble trying to make my own?
Thanks |
Posted: Sat Mar 10, 2007 4:43 pm Post subject: |
busman40 wrote: | They were downloaded from POIhandler.com and only when put on unit did i see the matching icons. Can i download them from here because i have had trouble trying to make my own?
Thanks | Their TomTomGo guide suggests you should have a BMP with the OV2s. I'd suggest you contact them at support@poihandler.com. _________________ Jock
Posted: Sat Mar 10, 2007 5:06 pm Post subject: |
pm me your email and i will send the bmp you listed |
